View unanswered posts | View active topics It is currently Mon Jun 26, 2017 8:12 am
what's after R290
Post what's after R290
anyone know what the roadmap is after R290? when will the next gen ATI cards come out.
i usually skip a generation when it comes to GPUs, so i am skipping the R290 gen.
Mon Jan 20, 2014 3:15 pm
Post Re: what's after R290
I don't think they have any leaks yet. R9 series only just came out, and they need to do the lower end series still.
NVIDIA's Maxwell is due soon though, starting with a lower end card the 750Ti.
Generally speaking though, GPU performance hasn't had any significant gains in the past 3 years.
Mon Jan 20, 2014 3:30 pm
please don't make me lock this thread.
Mon Jan 20, 2014 5:33 pm
ya, I almost went with the R9's, but the heat and power consumption kept me away. I would have had to buy a bigger power supply to run two of those.
I had actually hoped the power consumption was related to heat dissipation, but after seeing reviews of aftermarket cards when they finally appeared, that didn't seem to be the case.
Tue Jan 21, 2014 1:28 pm
i actually had to upgrade my 600 watt PSU to 850 when i got my HD7950 and started overclocking it right away. for days i couldn't figure out why in certain moments the system would shut itself off. lol.
i don't know... lately with all the upgrading and back to attending my PC hobby, i am starting to think about what GPU i should upgrade next. it'll definintely be the generation after R9 at the very least. my current 7950 overclocked 50% for both core and memory run at the same speed as a stock GTX680 in real world performance. it'll be hard to justify the minor 10% gain to upgrade now. not to mention i spent some dollars on an aftermarket cooling for the card, i'd like to see it pay off.
Tue Jan 21, 2014 1:54 pm
Rumour has it, the "Black Edition" Titan is coming shortly. I think it would match your car nicely ;)
And eventually, the GTX790 should come out (dual 780 or Titan cores).
Tue Jan 21, 2014 6:19 pm
all this talk of upgrading...I may have to take advantage of EVGA's step up deal LOL
Wed Jan 22, 2014 4:02 am
Stepup to what? Maybe a 770?
Wed Jan 22, 2014 4:09 am
AFAIK he has dual GTX780's, so 770 would be a downgrade
You are in like 3rd place ;)
Wed Jan 22, 2014 4:48 am
FFS... :doh:
I only read half his siggy which shows the gtx660
Wed Jan 22, 2014 8:05 am
