View unanswered posts | View active topics It is currently Fri Jun 23, 2017 8:14 am
Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3
Question about monitors
Post Re: Question about monitors
All this chit chat about ultra wides so what about the 27" 2560x1440 monitors?
Would one be a substantial upgrade to my current monitor?
Wed Feb 05, 2014 6:52 pm
I would personally say so. 1080p on 27" just doesn't look very good (my dad has one) compared to my 1440p 27".
Is it worth $500 though? Probably not. You'd want to move to 30" I think so you feel like your "upgrading"
Wed Feb 05, 2014 8:31 pm
I think you misunderstood me. Or maybe me you.
My current monitor is 1920x1080
I was considering a 27" 2560x1440 but then again..not.
since 30" are just way too expensive im gonna try the ultra wide for gaming.
Im buying it locally so I have 30 days to decide whether I like it or not.
Thu Feb 06, 2014 7:04 am
i just planced an order for an i1 Colormunki Display calibrator. i am excited. my previous calibrator was a Spyder2, which was useless for modern LED based monitors.
i plan doing some testing and see how accurate my last calibration was, which was done by using one of the Spyder3 Pro that i borrowed from work.
i am also going to for the first time attempt to calibrate my Samsung 60inch ES8000 LED TV by using the HCFR calibration software. it's gonna be quite a bit of work and a daunting process. consider the TV calibration isn't automated like monitor calibration, it's gonna take lots of tweaking and playing around, wife's gonna hate me.
Thu Feb 06, 2014 3:05 pm
I understood you, maybe my post wasn't too clear.
If you had a smaller-than-27" monitor at 1080p, say 23", and you were upgrading to a 27" 1440p monitor, that would be all fine and well.
Side-stepping from a 27" 1080p to a 1440p seems pointless though. You'll see improvements in fidelity/sharpness, but the size will be the same so there won't be much of a "WOW" factor.
Thu Feb 06, 2014 6:16 pm
Yea I found that out watching a few demos on youtube with 2x 27" monitors side by side . One at 1080 and one at 1440.
Really no difference to speak of.
If they were more generous with the 30"ers I would get one.
you would think by now prices would come down.
Fri Feb 07, 2014 5:19 am
if we're all getting technical, watching videos and movies, you should always watch it on the native resolution of the video. since 1440P monitor will need to up-res and stretch the pixels to fit 1440, the result is it's gonna look the same or worse than watching it on a 1080 monitor if the video is 1080.
the real difference comes in while playing games and other tasks like design and editing. you'll see a sharper image in 1440 at the same size, and due to the higher dense pixels, you "might" be able to lower your MSAA setting, since there's already more pixels to begin with compare to 1080, less edge up-res is needed to get rid of the jagged.
Fri Feb 07, 2014 8:58 am
The AOC q2963 was my choice.
And in short let me just say awesome.
picture quality just ootb is better than I thought.
The extra real estate is fantastic with gaming. FOV greatly improved.
No motion blur with BF3 at all that I have seen. The game recognized the resolution immediately.
Im pleased thus far.
Tue Feb 11, 2014 7:04 am
In BF4, you should be able to increase the FOV to make better use of the real estate too.
Tue Feb 11, 2014 2:39 pm
