View unanswered posts | View active topics It is currently Fri Jun 23, 2017 8:26 pm
Reply to topic  [ 6 posts ]
Installing OS via USB
Post Installing OS via USB
Hey, i've been trying to install OS via USB, and having a really hard time...first since the netbook i'm working with came with XP, i tried with that, and i can't get the image to boot, then i tried with ubuntu as well. with ubuntu was able to get it to boot, and load the image but it would not install...any tips, or links to a good how-to?
Intel Core2 Q9400 3.2ghz / DFI Blood Iron P35 T2RL / 8gb G.Skill DDR2 800mhz / ATI Radeon HD 5850 1gb / WD Black 500gb (SSD soon) / Antec HCG 620W / Antec 300 / Windows XP pro/7 pro x64/Ubuntu 12.04 / Samsung Syncmaster P2370 23"
Tue Dec 06, 2011 9:55 am
Post Re: Installing OS via USB
Hmm I've never had any issues...
Install XP would be very difficult from USB, but Ubuntu/Linux and Windows 7 are simple.
For Linux, I've used: http://www.pendrivelinux.com/universal- ... -as-1-2-3/ with success.
For Windows 7: http://www.winsupersite.com/article/win ... memory-key
Tue Dec 06, 2011 1:57 pm
you came to mind when i was having these issues...i knew you'd be the first to post...my first problem was i was getting this error on boot: "unknown keyword in configuration file" I did a search, and found a work around where i modified the config file, then i was able to get to the install menu, but if i made any selections, i get a dialog box that says "casper/vmlinuz" with an OK button, you click OK and nothing happens, i'm pretty sure it has something to do with the kernel installer, but i don't understand why i can't use GRUB to boot, the guide i used calls for syslinux, and i'm not even sure what that is...i'm still a linux noob after 2 years!! thanks for the links, i'll read through them...
where's st.louis? wasn't he a linux geek as well?
I would have liked to do XP since the license is on the bottom of the netbook, so i created an image of my windows xp cd in Linux, but i hit a dead end trying to boot it...
Tue Dec 06, 2011 2:43 pm
turns out XP is a fail, and Ubuntu 11.10 doesn't work with this particular netbook, primarily, the graphics hardware...used an older version, so far so good, but really wishing i could install XP, it's the wife's and she's very DOS based...
Tue Dec 06, 2011 3:48 pm
Yeah, to properly install XP from a USB drive...it's just not worth it.
I'd say pickup an external DVD drive instead. Should be able to find one for like $20-30 (on sale). Then installing XP will be a breeze!
Tue Dec 06, 2011 7:10 pm
nah, ubuntu 10.4 will do...a friend from work told me mandriva is good and somewhat dummy proof out of the box...
Tue Dec 06, 2011 8:06 pm
