View unanswered posts | View active topics It is currently Sun Aug 20, 2017 2:10 pm
Audio jack acts up??
I don't know if i should post it on motherboards or laptops so I'm just going to do it here. A problem I am experiencing recently with my laptop and headphone (both new) is that at times the sound switches to my laptop's speakers. Both normally work fine and even if I wring the jack or slightly pull the cable it remains so. I always figured I accidentally pulled it or something and there are no buttons that do this either.
This time I was even away from the damn thing when it happened. I've seen and solved many strange things but the timing is just to random to solve. And it doesn't happen often at all either. Sometimes it's hard to tell if it was so or not because I had the headphone on loud to. But I use it on the train and to play H-games/Eroge's since it isn't powerful enough for serious stuff so I don't want it to go to speakers at bad timing. Should I call mythbusters?
Tue Aug 30, 2011 10:36 am
Post Re: Audio jack acts up??
I think I found it out. This time by moving the headphone it kept changing. I guess some wire is lose or so. When that happens the laptop doesn't recognize the headset and switches to speakers.
Thu Sep 01, 2011 10:09 am
Thas good. Im glad we could help. ;)
Wed Sep 07, 2011 11:06 am
