View unanswered posts | View active topics It is currently Fri Jun 23, 2017 8:25 pm
Reply to topic  [ 1 post ]
brainstorm with me - dell 640m issues
Post brainstorm with me - dell 640m issues
so my moms laptop.........a dell 640m = > sloooooooooooowwww
seriously. i dunno whats up. its not spyware virus, the thing is clean. its not temp related, cpu sits at 40-44, hard drive is at 35 which to me is surprisingly though for a 7200rpm drive in a laptop
this is the one that we upgraded ram in, to 2gb kingston value ram. also put windows 7 on. but its "designed" for vista, so that's really a non-issue, or should be in the "real world" but it is dell....
its also the one i upgraded the wireless card in to an 802.11n intel 4965.
basically, its at the point, where it works fine for a bit, then starts to crawl, to the point that it takes 5 seconds for every key on the keyboard to respond. so i have to shut it down, pull the power, yank the battery, and hold the power button for a minute to discharge whatever, and then it works fine for a bit
right now i just did that again, and its on AC power only at the moment with no battery. seems ok at the moment, but its only been 10 minutes
i'm wondering if the battery might be bad? thoughts?
i also have a 630m here, that i know has a cr2032 battery on the mobo just under the keyboard, i'm going to check the 640m to see if its the same, and test the battery if it has one, i'm wondering if something like that could be causing issues.....
this thing is just pissing me off now, makes me wanna bitchslap that dell guy for being a cheap mofo
Sun Sep 19, 2010 2:07 pm
