View unanswered posts | View active topics It is currently Wed Aug 16, 2017 8:18 am
Reply to topic  [ 13 posts ]
my plan for my new build advise helpful
hey this is a my plan for build it all started cause i had to have this case so i got it now i have to put something all some in it heres the list
cool master storm trooper <-- case i had to have
rampage iv extreme
intel 2600k
RipjawsZ F3-19200CL10Q2-64GBZHD (8Gx8) (www.gskill.com)
have a 2tb western digtal plus a couple 500gbs
looking at Corsair 850W AX-850 ATX
and a Asus BC-12B1ST as optical
still haven't decided on graphics card tell me what you think this is my first full build. normally just upgrade my old pc
thanks.
Thu Dec 15, 2011 1:54 am
Post Re: my plan for my new build advise helpful
That looks quite fine.
Though unless you plan to do some serious overclocking (lack of watercooling makes me think no?) then you don't really need the Rampage IV Extreme. There's cheaper models that would perform just the same.
As for graphics, ATI has some new stuff in the pipeline come January. Not sure if it'll be a true launch or just a paper launch though. Might be worth waiting if you can. Some Z68 motherboards have video output that would work for basic usage. If you need to buy now though, I'd say GTX560 or GTX570.
Thu Dec 15, 2011 4:59 am
A couple issues with your component list:
Rampage IV Extreme - LGA2011
Maximus IV Extreme - LGA1155
Based on the 2600k processor you chose, I'm guessing you meant to list the Maximus.
You also listed a 64GB memory kit. The Maximus only supports 32GB. What are you doing that requires so much memory?
As for a video card suggestion, it really depends on what you're doing with the machine and what types of games you play.
Thu Dec 15, 2011 7:35 am
lol guess I ought to read things more carefully ;)
Alternatively, could swap the CPU to the i7 39370K and keep the rest!
But yeah, 64GB is likely overkill. 32GB wouldn't be so bad, and the bare minimum would be 16GB IMO.
Thu Dec 15, 2011 4:00 pm
was planing on over clocking just want to get it up and running and then see if i need it
and rampage was correct was half asleep when typing meant to b a Core i7-3930K forgot to change on my list of
parts. as for ram i probably will bring it down to 32GB and to answer you qestion of gamming normally online shooters
and a few mmorpgs or things liker witcher,bioshock and hitman.
Artificial Intelligence is no match for Natural Stupidity.
Those who criticize our generation forget who raised it.
Thu Dec 15, 2011 7:52 pm
zabzz ... welcome to The Computer Cabin forums.
I am currently building a few rigs for customers and one build includes the EVGA GTX 560 Ti Superclocked video card. So far, I am liking it. $229 after $20 MIR ... can't go wrong :handgestures-thumbup:
Fri Dec 16, 2011 11:06 am
Well in that case, since it sounds like your going all out, I'd strongly recommend waiting a few months to see what the new GPU's yield. You could buy a 560Ti to use temporarily though since it's fairly cheap.
Also, better steppings of the LGA2011 CPUs are due out in Q1 2012, so I'd say wait for those too. They fix some of the errata that exists in the current CPUs.
Fri Dec 16, 2011 2:22 pm
Say what? New HW coming out ? Yippee...time for a rebuild!
Fri Dec 16, 2011 5:49 pm
Didn't you just rebuild something?
Fri Dec 16, 2011 6:17 pm
Yep but thats beside the point. :mrgreen:
Fri Dec 16, 2011 10:50 pm
AMD's new high end GPUs look to be very interesting...time to switch back to the Red Team?
Nothing too interesting on the CPU front until Ivy Bridge.
Sat Dec 17, 2011 6:44 am
wont hurt to give it a look.
Sat Dec 17, 2011 1:23 pm
waiting seems like a good plan give me more time to get more money together thanx for all the advise been really helpful :mrgreen:
Sat Dec 17, 2011 10:52 pm
