View unanswered posts | View active topics It is currently Fri Jun 23, 2017 3:12 pm
Reply to topic  [ 57 posts ]  Go to page 1, 2, 3  Next
Thought this part needed a new thread...
Post Thought this part needed a new thread...
So I'm going to be teasing now :D
Pics to follow soon....
Thu Jul 07, 2011 4:04 am
Post Re: Thought this part needed a new thread...
I just filled up a pretend $3000 shopping cart on Newegg and sit and stared at it a while. It sure felt good. I really need help. :(
(help funding it that is)
Thu Jul 07, 2011 6:31 am
Its always nice to dream mate, but this dream of mine is turning into a reality :)
Thu Jul 07, 2011 2:11 pm
Here's a little something for you guys...
Its not quite the update that I was hoping for but never mind, I think its about time for one :)
I wonder whats inside the box.....
This looks interesting....
And whats it looking like with something in there....
There's a lot more to come...
Thu Jul 14, 2011 6:13 am
I'm not a big fan on acrylic cases. They are absolute dust hogs :P
Do share you secrets on keeping black acrylic clean!
Sat Jul 16, 2011 10:44 am
I just wipe it every so often!! :D Plus there is more to come.....
Read on please JD....
I did have a few issues when putting this case together.. It wasnt anything major but I was happy when it was all sorted!!
As you can see from the pic, the screws where too long for the holes so I had to drill through to make them big enough
Fortunately it really wasnt that much drilling to do as the screws werent anymore than 10mm longer than they should have been, so I was happy :)
When adding things into the case, everything fitted perfectly. This case was so simple to put together it was a dream to put together :)
Hard drives in place:
With the drives in place and in sort of position, I went to work on the rest of the bits I had laying about :) The radiators went in:
After everything was added into it that I could until some more bits get here, here's what we were left with :)
The reason for the neoprene on the back of the radiators were to not only space out the screws a little but to also help protect the case a little more too :)
Right now, here's the money shots I hope :D
I got two :D
I thought whilst I was getting one customised, I'd get another whilst I was at it :)
They now fit 10 hard drives and allow me to use 2 quad radiators and a triple radiators which is just perfect for what I was wanting to fit inside them :D
I'm just waiting on a few other things to come to finish these off and then its a case of waiting on my bits to come in at Scan and then I should finally have these things finished!!
I hope you guys are enjoying the build :) I've got a few more pictures of the older hardware and a few changes that have happened with those :)
I'll update again as soon as I can for you all and I hope its something that people are interested in seeing finally finished :D
Sat Jul 16, 2011 3:31 pm
Personally I would of bought smaller screws rather than drilling it out...but that's just me ;)
Is everything in these acrylic or does it have a steel/aluminum frame? Curious because the acrylic case I had was pretty flimsy once it was loaded up with hardware as it was only joined together with some cubes in every corner.
Sat Jul 16, 2011 3:48 pm
I would have gotten different screws mate, but because the US is in imperial and the UK is in metric, sizes were an issue!!
Its all acrylic mate and one thing I will say, its not flimsy at all.. Its bloody strong and weighs a tonne with all that hardware in!! Its very very well put together with how its been designed and how it fits. No issues with my cutting my hand on sharp pieces or anything, I was and still am, very impressed with both :) So much so I'm going to get another but a different design :)
Sat Jul 16, 2011 5:11 pm
Can't buy any imperial screws in the UK? Here in Canada we have both, even though our country is technically metric.
You could of also sawed down the screws too ;)
Sat Jul 16, 2011 6:11 pm
That's slicker than owl shit Phil. :dance:
Sat Jul 16, 2011 6:20 pm
I did try the sawn off screw idea but that was such a pain in the arse it never worked.. I couldnt grip hold of the screw when I was taking the nut off so I couldnt get the screw end right to thread in, it was a bit of a mess :( I could have gotten some imperial screws, but I just couldnt be bothered to wait!!
Many thanks for your comment mate :) I'm just getting started as well :) Roll on when my graphics CARDS turn up... I have to make a call tomorrow and if I dont get the answer I'm hoping for, I'll hopefully be buying them from Germany.....
I cant wait to get it all tubed up and ready to go mate :D Its been a bloody long time coming thats for sure!!
Sun Jul 17, 2011 3:07 am
Yep...it will interesting to see how it looks and reacts to any lights. Are you doing a waterloop in it? (now I will go back up and read everything) ;)
Sun Jul 17, 2011 12:39 pm
I'll post some pics up for you tomorrow Comixion.. I'm just finishing off one of the cases tonight and then hopefully the other one tomorrow :) Although I have a feeling that I dont have enough tubing!! :lol:
Sun Jul 17, 2011 2:53 pm
Ok, it's tomorrow.
Mon Jul 18, 2011 10:29 am
How's this Comixion??
And here's a bit more:
I'm hoping to get it leak tested very shortly, but I'm going to check the CPU block as before I had some higher than I should have temps, so I'm gonna check it out, just before I start filling the damn thing up :)
Mon Jul 18, 2011 11:14 am
nice.....Is that 7/16 ID on 1/2" fittings or you just have not put on the clamps yet?
Mon Jul 18, 2011 11:22 am
It is it need Sir :)
That way I dont have to use clamps or anything :)
Mon Jul 18, 2011 11:26 am
Good idea imo. Clamps are so unbecoming. I'm considering a redo myself with the 7/16ID. This time blue maybe. Is that Feser or Primochill? Or? And what are gonna use for da juices?
Mon Jul 18, 2011 12:06 pm
Its neither mate. I believe its XSPC stuff, I will find you a link :)
I'm uses the best of the best here mate... Asda's De-ionised water :) I gave up with all the coloured liquids after the mess it made in my res!! I just use coloured tubing instead now :)
Mon Jul 18, 2011 12:15 pm
How come that last picture the X58 logo looks dirty/rusty? Is that how it's supposed to be?
Mon Jul 18, 2011 12:38 pm
