View unanswered posts | View active topics It is currently Mon Aug 21, 2017 3:14 am
Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
The FT01 Re-Build
Post The FT01 Re-Build
Well here's the pictures you guys wanted. Main changes as follows:
  • Laing DDC3.25 pump
  • Koolance HTS-PMP400 (pump heatsink). I've attached a 60x15mm Delta to it as well.
  • Lamptron FC-6 fan controller with one probe in between the pump and pump heatsink. Maybe more around the motherboard later.
  • XSPC Black Aluminum faceplate. New ones come with this, but I had the original model that was just shiny black acrylic.
  • EK Nickel Plated backplate for the GPU. No real function IMO but looks slick.
  • Single sleeved PCIe power cables.
  • Indigo Xtreme Thermal Interface. Uses Phase Change Metal Alloy (PCMA).
  • Thermochill EC6 UV Blue Fluid. Seems a bit lighter than Feser One.
  • 3x1TB Samsung F3's in RAID5 alongside the Vertex 2 120GB SSD.
Image Image Image Image
Image Image Image
And I got a nice counter for my PC now too :mrgreen: Since we're re-doing our kitchen, this new cabinet ended up being too small. So I inherited it, found a nice piece of stainless steel (it's a cabinet door actually) at IKEA, and screwed that to the top. It's a bit tall though, but I'll probably get used to it. Makes my PC the showcase of my room ;) I need some longer cables now though....
Wed Aug 25, 2010 6:28 am
Post Re: The FT01 Re-Build
that looks kinda technical....i don't do technical
looks good, i see you took the pics or ban warning seriously ;)
Wed Aug 25, 2010 6:43 am
Wow JD...that system looks sick. Nice job.
Thu Aug 26, 2010 3:38 am
Great pics JD!! I have yet to finish the remodel job on the Computer Cabin workroom ... too many other projects going on. Had to re-do the chimney stack for our woodstove the last week or so. I'm using the Boss's iMac to type this. I don't get on her computer that much but thought I'd check in today to see what's going on.
Great work! :handgestures-thumbup:
Thu Aug 26, 2010 9:37 am
Just be sure to use CCleaner when you are done using it and clear out your internet history. :lol:
Thu Aug 26, 2010 9:48 am
Yea JD....nice indeed.
Thanks guys. Still got a few more little things to do and cleanup though...
Thu Aug 26, 2010 6:07 pm
well, whats taking so long, finish it up and send it to me, i'll let you know how it works ;)
Fri Aug 27, 2010 2:29 am
Waiting for it to come in the mail?
Fri Aug 27, 2010 10:22 am
yeah, i'm still waiting, where is it
Sat Aug 28, 2010 5:12 am
Well my P-PCs order showed up today, so I'm nearly complete now. Just need to hookup my DVD-RW (need to get it some power) and then cleanup the fan controller wires in the bays.
The notable addition today is the switch to turn on/off all the lighting. By total chance, it fit perfectly into the pre-drilled watercooling holes (which are absolutely useless otherwise). So it gives it a pretty clean, factory look I'd say.
And for reference, the Phobya Y-cable 3Pin Molex to 4x 3Pin Molex (http://www.performance-pcs.com/catalog/ ... s_id=28837) works great with the Lamptron FC-6 to split one of the channels. Now all my radiator fans are on 1 channel while still showing the RPM too.
Also my sidepanel nearly sits flush now! At least it's not as noticeable as it was before.
Thu Sep 02, 2010 8:30 am
I have to say I like the blue tubing.
Thu Sep 02, 2010 9:35 am
Maybe it's time you got some in that HAF-X of yours ;)
Thu Sep 02, 2010 11:20 am
To cool what? This 460 is an iceberg compared to that 480. :)
Oh yea, the CPU? Hmmm...I just may. How much is all that sweetness? Of course I only need to route to my cpu.
Thu Sep 02, 2010 12:10 pm
that switch is hardly noticeable, nice.
keep the pics coming
Thu Sep 02, 2010 1:05 pm
I can't really say... I've bought things over the course of many years and have re-used tidbits. However in total the amount I've spent on watercooling-related things is probably nearing the $1K mark? All I know is that I have a fair bit of shit in my closet. I have a whole loop for that matter (D-TEK FuZion v2, MCR220, MCP355, Bitspower Bay Reservoir, bunch of fittings, tons of bits of tubing, fans, etc)
But to setup a CPU loop with some decent gear, probably looking at around $300-400.
Thu Sep 02, 2010 5:20 pm
Its looking good JD :D Old post I know but I thought we needed to revive this section a bit!!
Wed Mar 30, 2011 3:15 am
Some up-to-date pictures:
Sat Apr 09, 2011 8:52 am
Its looking great JD :D Are you happy with it?
Sun Apr 10, 2011 4:00 am
For the most part ;) I have the urge to upgrade though :lol:
I mainly want to find a decent looking case (re: not a square box, not over-the-top) that fits a 120.3 radiator internally though. The TJ11 is close to meeting that, but it's fucking expensive and the intake holes for the mid-180mm fans look half assed.
Sun Apr 10, 2011 5:54 am
