View unanswered posts | View active topics It is currently Fri Jun 23, 2017 11:39 am
Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
AMD Phenom II X6 Build
Post Re: AMD Phenom II X6 Build
Very nice build JD, and excellent report. I definitely want you on my web-page as an editor and writer when it comes to doing reviews. You're hired!! :handgestures-thumbup:
Sat Jul 03, 2010 7:29 am
So JD, you're getting about 400w on full load? It seems to me if I do a similar build, I should get away with a 500w-600w PSU. Well depending on what video card I get.
Sat Jul 03, 2010 8:53 am
Only if I get free hardware! :mrgreen:
Yeah 600W would probably be adequate. I'd say go with 750W though since you typically don't want to run too closely to peak wattage.
Sat Jul 03, 2010 5:26 pm
hey uhh, JD, if you decide that stock amd cooler isn't enough, let me know, i'll take it off your hands if you replace it
Wed Jul 07, 2010 3:11 pm
Sure thing. Might go with water, but we'll see in time.
Wed Jul 07, 2010 5:01 pm
i'm thinking of a water setup....i need water blocks though, maybe a pump, i'm thinking of using the spare fuel pump i have for the car if it'll work
Wed Jul 07, 2010 5:19 pm
I am thinking that would be an external setup you'd be using ... just how big is that fuel pump anyways?
Thu Jul 08, 2010 12:38 am
its a fuel pump for a tercel, the outlet is 3/8, but it'll crank about 70psi, and should run off 12v dc. i have access to a a thermaltake 120mm triple rad, as well as a single that i can borrow. a reservoir should be easy to make shift and i have some pretty highspeed 120mm fans as well, they're louder than the effin tornado's..... all i'd need to buy is at least a waterblock for my x4 and some coolant maybe
Thu Jul 08, 2010 2:21 am
Coolant? Try windshield washer fluid, the kind that doesn't freeze, like stays fluid @ -20F ... that's what I used. :handgestures-thumbup:
Thu Jul 08, 2010 4:42 am
thats a good idea, and its dirt cheap too.....
sorry JD for thread jacking, ill start a new thread for the water block i'm looking at
Thu Jul 08, 2010 5:18 am
Ahhh ... don't worry about him ... remember who you're talking to ... the prince of thread-jacking ... :text-threadjacked:
But we all know who the King is ... :character-burgerking: ... no not him ... :lol: ... this guy ...Image
Thu Jul 08, 2010 6:05 am
Quickly playing around, with leaving all the voltages on auto and I got this:
Though the memory is under spec, at only 1100MHz or so and CL9 timings. Next jump goes too high though for the RAM and it won't POST.
And since the picture doesn't show it, it's 4004MHz. Not bad for auto volts :mrgreen: Not sure how stable it was though since I only did this 1M SuperPi.
Also 290MHZ on the bus was a no go. Wouldn't POST, but luckily the board is smart enough to detect that and reset itself. Even comes up with a prompt showing you your settings when it failed.
Mon Jul 26, 2010 2:23 pm
Time to revive this thread!
Since I had a bunch of watercooling parts kicking around, I figured I'd put together another loop. This consists of a Swiftech MCR220 (w/ S-FLEX "F" fans), D-TEK FuZion v2, EK FC5870 and my modded pump. Connected all together with Primochill ProLRT UV Red 1/2"ID 3/4"OD tubing and some basic Bitspower 1/2" barbs. Fluid wise, using Feser One UV Red, but you don't really ever see it.
Had a bunch of leaks unfortunately...both radiator barbs leaked and the GPU block leaked. I fixed the radiator by doubling up on the o-rings since the Swiftech radiator threads are recessed a bit. Seems to have solved the leaks. As for the GPU, I had it apart a while ago and I guess I didn't quite get the o-ring in properly, so I had to take the block apart again and reseat it with the help of some Vaseline this time. Leak-free once again :)
I must say, the HAF932 is much easier to work in compared to my FT01 ;) But regardless, I'm still not a fan of the looks of the HAF.
Temperatures look pretty good, both CPU and GPU idle at 28C. Haven't done any major load testing yet, but I run a full 3DMark11 loop (demo and bench) and the maximum temperatures were 36C on the CPU and 34C on the GPU.
And a totally stock 3DMark11 run:
Sat Jun 18, 2011 1:39 pm
Nice JD. But wasn't it you that scolded me because my waterloop didn't match my Mobo? ;)
And you must have a pretty nice camera to make red tubing look "red"
Sat Jun 18, 2011 2:17 pm
lol well I matched the case instead since it's the AMD edition of the HAF932 so it's all red ;)
And the first 2 pictures are more orange to me, but the 3rd one is nice rich red. So long as it's not in direct light (which the first 2 are), the tubing looks red.
Sat Jun 18, 2011 4:14 pm
Yep I noticed that. I was refering to the 3rd one. I happen to be sitting here with my daughter's Nikon trying to figure out all these crazy settings. Hoping to become an overnight sensational photographer. :roll:
Sat Jun 18, 2011 5:48 pm
UV lighting would probably help quite a bit...maybe I'll get a 12" tube when I have other things to order ;)
Rear fan is a Xigmatek 140mm Red LED and there's the original 200mm Coolermaster Red LED fan in the front of the case.
Also stepped down the radiator fans (S-FLEX F) to 7V to make the PC pretty much silent.
Here's the night shot:
Sun Jun 26, 2011 4:33 pm
Upon further thinking, I decided that sound card (Xonar DX) looked ugly sitting above the lovely nickel backplate, so I moved it under the GPU.
Sun Jun 26, 2011 4:54 pm
Awesome build there JD :)
I'm looking to do something similar with a setup here, but I'm unsure if I'll be water cooling it tho :D Trying to make it as energy efficient as possible :)
Tue Jun 28, 2011 3:47 am
Users browsing this forum: No registered users and 2 guests
