View unanswered posts | View active topics It is currently Wed Aug 16, 2017 8:14 am
Going to upgrade plus use old parts
Post Going to upgrade plus use old parts
Hi I amm new to this site I now have a Gateway DX4710-09 With 6g and just added a ssd 240g Worked fine after some work around I am going to use an ASUS F2A85-M PRO with a new Case Midtower & 450 power supply & 8g 2x4 DRR3 1600. Would like to use my ssd & load Win 7 Pro Shold i Keep my old drive. I changed it to F. drive it is 650g. My CPU now is Intel & my new motherboard has AMD. Any thoughts.
Sun Dec 14, 2014 10:42 am
Post Re: Going to upgrade plus use old parts
The only thing I would suggest is formatting the drive and installing Windows fresh.
As to keeping the 640GB hard drive, that's up to you. If you need the space, sure why not, if the 240GB SSD is sufficient, just use that. I'd only store things like pictures, videos, documents on the hard drive regardless. You want Windows and any programs/games on the SSD.
And welcome to the forums!
Sun Dec 14, 2014 6:12 pm
Thank you I heard that intel & amd are not compatable so yes I am going to install win 7 after a new format on the ssd and on the hdd do i need to do any thing but remove win 7.
Sun Dec 14, 2014 8:14 pm
You could even leave your HDD as-is, as long as it isn't set as your first boot device.
But yes, you can delete the Windows folder and Program Files folders
Mon Dec 15, 2014 3:40 pm
