View unanswered posts | View active topics It is currently Wed Aug 16, 2017 8:28 am
Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
Here we go again...
Post Re: Here we go again...
Yeah, I have a UV LED strip up top there alongside the radiator. You can see it in the 3rd pic as the tape doesn't quite hold that end due to the cable being jammed in the wrong direction :whistle: I should really clean that up, but it would mean either drilling a hole or moving the LED strip off-center.
I have another in the bottom too (which you cannot see) but it seems to have burned out at some point. I hadn't really done anything to my PC for the past 2 years (those last pictures were Nov 2012). Obviously a little more maintenance is required!
I should also replace the stock front Blue LED fan too with a Red one. Something I've been meaning to do but never have.
Fri Sep 05, 2014 12:56 pm
it does look mighty purrrty. Really makes me want to go WC, or even just add lighting to my cases again which I haven't done in years.
Sat Sep 06, 2014 3:52 am
i recently built a rig for my friend using Corsair H100i. i was pretty impressed by the performance. it's not as good as a custom loop, but it was way better than air cooling. i was able to push his 3570K quite well.
Sat Sep 06, 2014 8:31 am
Did you buy the ram specifically because it was red? ;)
Wed Sep 10, 2014 6:00 pm
Of course :P
Wed Sep 10, 2014 7:50 pm
they have to match right. They can't not match, that would be pure blasphemy
Thu Sep 11, 2014 12:16 pm
