View unanswered posts | View active topics It is currently Sun Jun 25, 2017 3:14 pm
Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
Here we go again...
Post Here we go again...
Couple teaser shots for now, still awaiting other bits and pieces...
Sun Jun 24, 2012 7:17 am
Post Re: Here we go again...
Rampage IV Extreme :mrgreen:
I still have blue and orange tubing kicking around, so probably stick to that. Maybe red later down the road. I don't know though, I'm still waiting to find a GTX690 block I love, so with that order may come new tubing ;)
Sun Jun 24, 2012 5:15 pm
Yeah it's not bad...but I'd rather something like this http://shop.watercool.de/epages/Waterco ... ucts/15521
Main issue I have with XSPC is that they don't offer a backplate. And at 1.35kg for the block itself, I'd kind of expect one.
Mon Jun 25, 2012 2:06 pm
Yea I have been reading up on that one. I don't see one for a 690 listed.
funny: sold out - Pre-possible - probably available again in week 27
As for the backplate...just use one you like. doesn't have to be of the same brand...I don;t think. :think:
I'm gonna use eVGA's bp jst because its and eVGA card but I may sway. Still looking.
Dam I like that Mushkin Redline series. What are the timings?
DDR3-2133 9-11-10-28
And yeah I know any backplate would work, but nothing else exists currently. Really strange. EVGA is expecting 2-3 weeks for example. I don't get whats so difficult about a piece of metal with some holes in it...
Mon Jun 25, 2012 3:56 pm
noice
Mon Jun 25, 2012 5:13 pm
Minor progress...
CPU and EK Easy Mount posts installed. Hopefully they work with my HK3.0, otherwise some choice words will be uttered when I go to install it.
Wed Jun 27, 2012 4:17 pm
Temporarily together now, until I decide upon a GPU block. Then I'll have to drain both loops and what not. I have a feeling I'll end up buying either red or black tubing as well.
Sat Jun 30, 2012 8:17 am
Why are you running 2 loops?
Easier to remove the GPU? Because I can? :P
Sat Jun 30, 2012 7:12 pm
I'll probably turn it into 1 loop with dual-pumps though once I get a GTX690 block.
Thinking I might flip the top rad around too so the barbs aren't so tight against the reservoir.
Sun Jul 01, 2012 2:54 pm
So my RevoDrive3 X2 showed up today...and it's pretty fast :mrgreen:
Thu Jul 05, 2012 4:40 pm
my that's sexy. what kind of camera are you using to take those shots? i'm sure that questions come up before, but i'm curious
Fri Jul 06, 2012 5:53 am
Canon 60D w/ Sigma 17-70mm f2.8-4 "Macro" HSM
Fri Jul 06, 2012 4:06 pm
I oughta come around here more often. I just love ROG Red!!
Tue Oct 23, 2012 3:30 pm
I think I can FINALLY call this finished! :mrgreen:
Mon Nov 05, 2012 9:13 am
Fantastic! As always, JD, great-looking pics!! :handgestures-thumbup:
Tue Nov 06, 2012 12:12 pm
Thanks guys.
The best part is that my GPU peaks at 41C now after playing BF3 and remains totally quiet :) No more of this 80C+ fan roaring GTX690.
Tue Nov 06, 2012 5:10 pm
Some minor changes...
Got a new reservoir + pump, the Monsoon Series Two Premium D5 (http://www.frozencpu.com/products/19742 ... 5P-RD.html) with a Swiftech MCP655-PWM pump. Far quieter compared to my dual PWM DDC setup before. Temperatures remain the same.
Thu Sep 04, 2014 12:13 pm
i am waiting for someone to give the hard piping a shot. JD?
Thu Sep 04, 2014 5:57 pm
as always, awesome stuff.
Thu Sep 04, 2014 6:55 pm
Yeah I've definitely considered it, but it would be so much work and a lot of tools/rigging to setup to do it right. I'd feel as though I'd have to double everything too since I don't think I'd ever like my "first" bend.
I'll do it eventually though, I convinced one of my friends to do it. He did an alright job but since he was just hand bending you can tell some of the 90's are squished a bit.
Fri Sep 05, 2014 5:09 am
