View unanswered posts | View active topics It is currently Mon Jun 26, 2017 11:39 am
Forum rules
Mac vs. PC battles WILL NOT be tolerated as it interferes with our ability to answer legitimate questions.
Apple computers and graphics cards
Post Re: Apple computers and graphics cards
Is it a newer Intel-based Mac? If so, I believe it should.
I know in the past there's been "Mac" edition GPUs with EFI BIOS on them, but now that EFI has come to regular desktops as well, most GPU vendors support it on all cards.
Sat Dec 13, 2014 9:23 pm
according to this, 600 and 700 series work with no modifications.
http://www.tonymacx86.com/graphics/6635 ... er-no.html
Sun Dec 14, 2014 9:48 am
^ I'm not sure if that applies to "real" Macs. I have a 660 in my hackintosh though and it works, so it might. they are more or less x86 machines now
just try it and find out :P
Sun Dec 14, 2014 4:42 pm
granted some things on a hackintosh require special kexts. But since the graphics works outside the box without problems, on a real make it should be same.
Mon Dec 15, 2014 2:50 pm
If you are booting the Mac Into Windows then yes, any GPU will work (to the best of my knowledge). If you want to run the card while booted into Mac OS X, you will need specific cards that support it. Example, I'm running a PC 5770 that works unmodified.
And yes, that comment about no fighting was me.
Tue Dec 16, 2014 9:39 am
