View unanswered posts | View active topics It is currently Thu Aug 17, 2017 11:43 pm
Reply to topic  [ 11 posts ]
Quick 3dMark vantage run on my 780's
Post Quick 3dMark vantage run on my 780's
So I ran a quick vantage run on my SLI 780's
I'm not sure if I'm supposed to reboot when I disabled PhysX, because I got essentially the same score both ways.
Without PhysX
With PhysX
wasn't able to submit the scores because my web filter is blocking it for some reason, but meh. I'm also not sure how the scores really compare, to be honest I'm not all that bothered since I've got a ridiculously unnecessary amount of gaming power now anyway
Sun Nov 10, 2013 10:05 am
Post Re: Quick 3dMark vantage run on my 780's
OH, got a 3D mark 11 score submitted
score 17641
http://www.3dmark.com/3dm11/7467108
i think I had physx off, but i can't remember if i turned if off before or after that run
Sun Nov 10, 2013 11:51 am
I would think you would have a much higher score with Physx enabled
Sun Nov 10, 2013 12:17 pm
What about the latest 3DMark?
Looks to be a bit faster than my GTX690, but still no reason to upgrade :P
Sun Nov 10, 2013 2:23 pm
Especially when im looking.
Sun Nov 10, 2013 8:23 pm
uhh, which ones the latest 3dmark? I'll see about running it tonight.
edit// i posted a 3dmark 11 score a couple posts up
score 17641
Mon Nov 11, 2013 8:26 am
It's simply called "3DMark". It's the only one available on Steam if that helps.
http://www.futuremark.com/benchmarks/3dmark or http://store.steampowered.com/app/223850/
The Demo = Free version.
Mon Nov 11, 2013 3:33 pm
oh, i see now. i'm falling behind apparently then. I'll have to do a run tonight then
Tue Nov 12, 2013 5:01 am
sigh....tried running the latest 3dmark demo last night. my system shutdown twice during the fire strike test. had a hardware monitor running during the second run and couldn't spot any temperatures going out of control, and of course, there's no bluescreen or any indication to why it shut down....
tried again this morning while i was getting ready for work. one thing I noticed last night was the fans on the videocards weren't speeding up under load at all, so I manually turned them up to 100% and it still shut down.
so now i have some work ahead of me, I'll have to do a prime run, and probly some memtest to make sure those check out. then I figure I'll run the test on one card at a time and see what happens. but then if they both work individually, maybe I'll have to start thinking about a power supply? BUT, my ups is rated 850w, and I only had the one system running on it last night and it wasn't going off, so I don't think my power supply would be hitting it's full 850w which leaves me at a loss for the moment.
I'm going to have to go through all the testing and hopefully spot something along the way
Wed Nov 13, 2013 5:03 am
Yeah Fire Strike is really the only "true" test now-a-days IMO. Only truly taxing benchmark. Catzilla and Unigine's Heaven/Valley would be my other choices.
Wed Nov 13, 2013 4:31 pm
yeah, catzilla is decent too actually.
I ended up re-enabling physx and my system finished the firestrike test. after running prime95 earlier two it errored on threads 7 and 9 which should equate to the 4th and 5th core on my cpu. might need to tweak voltage or something, but it looks like my cpu may have it's own issues.
i'm just leaving it as is for now, it hasn't hindered my regular day to day or other gaming so until it does, it can stay the way it is
Wed Nov 13, 2013 6:21 pm
Users browsing this forum: No registered users and 2 guests
