View unanswered posts | View active topics It is currently Wed Aug 16, 2017 2:31 pm
Reply to topic  [ 6 posts ]
Disabling Internet Access
Post Disabling Internet Access
Are there settings in an android tablet such as the Samung Note 8.0 to prevent it from "ever" accessing the internet via ATTs 4g.....not wifi. It has a 300mg limit per month (which they said I have to have) and its my granddaughter's and I dont want her racking up bytes. Only the wifi at home.
Wed Sep 25, 2013 9:43 am
Post Re: Disabling Internet Access
There should be an option called "Mobile Data", disable that.
If it's Android 4.x, it should be under Settings\Data usage.
Wed Sep 25, 2013 4:58 pm
if it's android 4, there should also be options to cap the data usage so it stops using data once it's reached the limit no? I know I have an option for that
Wed Sep 25, 2013 8:49 pm
Oh yea...sheesh.....I use that to limit my cell phone to the 3gbs plan I have.
Thu Sep 26, 2013 4:22 am
Hmmm....for some reason this one does not have the option to manage or set data usage limit in the "data usage" menu. Although online I checked and other devices like this one do. So Im assuming maybe a sw update. But this one shows the sw is up to date.
Sat Sep 28, 2013 5:08 am
Evidently ATT did it for me. I originally had a 2gb plan on it and called them to remove internet altogether but was told I was required to have at least a 300mb plan which I didnt want since its hard to govern a 5yr olds internet connectivity so I accepted.
However when I just did a test in my house and turned off the wifi to see if it would pick up ATTs 4g.....it would not at all. The tablet will not connect except via wifi. Also the number it was originally assigned is no longer showing on my account. Which is fine.
So is th8s something they did? Saying they disabled it from being able to connect other than wifi.
Thats what I wanted in the first place.
And how was your day?
Mon Sep 30, 2013 2:17 pm
