View unanswered posts | View active topics It is currently Sat Jun 24, 2017 11:36 pm
VirtualBox
Post VirtualBox
Anyone know anything about this program. At school we're building a network and installed server 2008 R2 on a virtual machine via virtualbox. Now we are having a problem of assigning it a static ip address. We tried host only, bridged network, and NAT network connections in virtualbox and can't figure it out for the life of me. Plan is to give the host OS (xp) a ip address and give the virtual os (server) another address.
Mon Feb 13, 2012 6:35 pm
Post Re: VirtualBox
You shouldn't touch the host's IP addressing.
What is your end goal? To have the host able to communicate with the VM? If so, use NAT and let DHCP take care of the rest. You can make it "static" by setting the values received via DHCP if you really must.
Mon Feb 13, 2012 8:47 pm
Post Re: VirtualBox
our end goal is to have the server on virtualbox with the ip address of 10.20.40.80 and the host machine with the ip address of 10.20.40.60. If that's not possible, I just want to bypass the host machine and have the server directly connected to the network.
Tue Feb 14, 2012 7:08 am
Post Re: VirtualBox
To connect the VM directly to the existing network, use Bridged.
VM-to-Host networking isn't really something you want typically speaking anyways. The whole reason for running a VM on your PC is to isolate it from your host (production) machine. The only way "around" it that I can think of would be if you had your own router that you could configure accordingly (so you could use your 10.20.40.x subnet). Then with the VM on bridged, traffic could go through the router and back to the host. I've done this in my labs at school as we had Cisco routers and switches at each pod (group of 4 PCs).
If it just so happens that the existing network is using 10.x.x.x 255.0.0.0 then you can likely get 10.20.40.x 255.0.0.0 to route through fine. If the existing network is subnetted or uses a different class of IP, then you're out of luck.
Tue Feb 14, 2012 7:34 am
Post Re: VirtualBox
so i am guessing we need to play around with the bridged connection some more. The topology we got is simple. 5 pcs connected to a cisco router via a cisco switch. Then that router has a wlan connection to another router which connects to our xp/server 2008 pc.
Tue Feb 14, 2012 10:31 am
Post Re: VirtualBox
Yeah, if the VM is bridged, then it acts no different than a physical machine.
That means you have some configuration issues on your router/switches to look at.
Tue Feb 14, 2012 11:40 am
Post Re: VirtualBox
I'll look in to it tomorrow in lab. I'm not the person who configured the network but I'll check it out tomorrow. Only thing I know is that they used OSPF as the protocol between the two routers.
Tue Feb 14, 2012 6:21 pm
Post Re: VirtualBox
You're running OSPF over WiFi? That seems like an odd configuration. Logic tells me it's doable, but I don't really see why you'd want to and I'm sure it's not recommended.
Tue Feb 14, 2012 7:32 pm
Post Re: VirtualBox
I misspoke when I described the topology. Meant to say WAN instead of Wlan. :doh:
Tue Feb 14, 2012 7:39 pm
Post Re: VirtualBox
haha, alright that makes more sense then ;)
Tue Feb 14, 2012 9:17 pm
