View unanswered posts | View active topics It is currently Sun Aug 20, 2017 2:12 pm
Reply to topic  [ 6 posts ]
Windows Update freezing
Post Windows Update freezing
I have never had this happen before.
Windows update freezing up about 2 seconds of scanning for updates.
I can I cancel but closing the window takes a few mins. I have to reboot
W8
:think:
Thu Jan 09, 2014 8:32 pm
Post Re: Windows Update freezing
might be something to do with win8, have you upgraded to 8.1?
i'll probably stil be running 7 for a while.
Sat Jan 11, 2014 10:17 pm
My bad....I have 8.1
Sun Jan 12, 2014 7:40 am
Try running "sfc /scannow". Sounds like something might be corrupted somewhere.
Sun Jan 12, 2014 8:34 am
sfc /scannow is useless on anything newer than XP, all it does is check files
but Win8 has this
http://blogs.technet.com/b/joscon/archi ... -2012.aspx
try the dism restore health command
but to be honest, if it's windows update, probly something corrupted in the software distribution cache. I'd try stopping the win update service and tossing the c:\windows\softwaredistribution folder first
Sun Jan 12, 2014 4:24 pm
i gotta say, ever since win7, windows update has been pretty bullet proof. i can't recall how many times it's in the middle of downloading update, and i happen to be testing my rig and overclocking, and BSOD, and yet, when i get back in, it just redownloads everything again, and nothing gets corrupted.
i would say, if your rig is stable, just leave it alone.
Sun Jan 12, 2014 6:19 pm
