View unanswered posts | View active topics It is currently Sun Sep 24, 2017 6:56 am
Reply to topic  [ 17 posts ]
Windows struggling
Post Windows struggling
Lately windows has been running a little slow. (W7). On startup it seems to take a little longer than usual and once it gets to the desktop it takes a few seconds for all the icons to appear. And on occasion just opening different windows has hesitation. I know the first thing you will say is I need an SSD and the second thing you say will be I need an SSD.
Anyways, can a HDD start going bad without necessarily showing it in scans?
Tue Jul 16, 2013 5:48 pm
Post Re: Windows struggling
here's something you can try
http://howto.cnet.com/8301-11310_39-201 ... windows-7/
have you checked your event viewer? there could be a service or driver failing to load because it's not there anymore, but windows might still be trying to load it. we see this a lot at work, logmein for example, once it's removed, it doesnt remove everything, generates alerts for services failed to start constantly, piece of crap
try downloading autoruns from the sysinternals site and see what's being loaded at startup
it could be your user account being gummed up that's causing the slowness. too many people mistake long logins for long startup times because if there's only one account on the machine and no password, then it tends to just autologin on startup.
try creating a second user account on the computer, and log into the other user, then reboot
on reboot, see how much time it takes to get to the log in screen, then see how much time it takes to log into the new user account, then log out and compare how long it takes to log into your previous account
Tue Jul 16, 2013 9:28 pm
Yes, buy a SSD and install Windows 8. Boot times will be a thing of the past (typically within 10 seconds).
Wed Jul 17, 2013 3:29 am
Windows 8? Sounds freightening.
Wed Jul 17, 2013 6:08 am
nah.. just buy an SSD. that'll fix your problem.
i recently FINALLY got my Crucial M4 256 for the HTPC rig in the living room. mind you that rig is hooked up to the home surveillance and recording 24/7, and it's also our main media center for TV, DVR, Blu-ray, Netflix, internet browsing, and some light gaming. all these things make the rig really slow to boot up, since it has to load a billion programs when it boots. even tho we don't reboot it very often, and it's always on 24/7. but everytime we reboot it for whatever purpose, it takes years for it to fully load into windows. with the SSD, it's like almost instant. i am thinking of getting another SSD for the gaming rig too, cause now that one seems like snail in comparison. after using SSD, you won't want to wait for anything.
Wed Jul 17, 2013 7:57 am
Home surveillance?
Like that movie "Lawless" only modern day?
Wed Jul 17, 2013 9:28 am
yup. wireless too with night vision. i am looking to get 2 more to cover the rest of the house.
Wed Jul 17, 2013 9:34 am
That bad around there ? Or just being safe. Where, may I ask, do you live again?
Wed Jul 17, 2013 11:04 am
Ok so I go get me an ssd. I just went through the agony of reinstalling windows and doing updates. I gotta do this again? And what SSD do you suggest and the size
Wed Jul 17, 2013 11:25 am
I buy OWC SSDs. They are practically identical to OCZ if you prefer that brand. And as far as size, get as much as you can afford?
Wed Jul 17, 2013 11:39 am
What size do I "need" to afford? I mean....is it ussd to just to install windows onto?
Wed Jul 17, 2013 11:48 am
Thanks...that helped a lot. Things are going smooth now. :clap:
Wed Jul 17, 2013 5:05 pm
glad that helped.
I think addressing the root cause of the problem might be key. you can't just reinstall everything or throw money at a problem without fixing the root cause
SSD's are fantastic, don't get me wrong, but a system can still boot slow after a while of getting gummed up if you don't address the correct issue. This is my way of saying you should still get an SSD, especially now that things are going better ;) just think how awesome it could be now. some SSD's even come with software to clone your drives, saves reinstalling
Wed Jul 17, 2013 5:19 pm
Ideally you want the OS and all applications on the SSD. Minimum enough room for OS.
Thu Jul 18, 2013 7:44 am
240GB is typically adequate. That's what my OS and apps are on.
Then I have my 480GB Mushkin Chronos with all my games, a 480GB RevoDriveX2 with all my VM's and a 120GB as a "scratch" disk so to speak.
Thu Jul 18, 2013 8:47 am
heh, I use small SSD's compared to JD
my DJ box has a 60gb SSD plus 750gb hard drive, but its special purpose and needs minimal application space
my Macbook has a 128gb with 40gb free
my i7 hackintosh has a 128gb plus 500gb hard drive
my i7 gaming system has a 2x60gb plus 750gb hard drive
my linux machine has a 60gb ssd for OS and applications and 3x1tb drives for storage
and my media center has a 120gb, though I've been looking at some of the games I have and thinking I might want to try more of them on the HTPC than I initially thought. it's crossed my mind that maybe 120gb may not have been enough....but i'm not sure yet
depends on your needs really and how much you want to spend. personally, I've had little need for anything over 128gb, 60-128gb has been enough for me to store my OS and software on all the machines I have with SSD's and use hard drives for personal data. if and SSD fails on me, i'm not hurt at all by it, other than the time to restore an OS from a backup image
it depends on the size of your OS and applications combined as well, and how much of it you really want to prioritize. also consider what data your willing to risk as SSD's are still kinda more prone to failure depending on who you ask
Thu Jul 18, 2013 5:17 pm
My desktop has a 120 GB Intel x25m, and the t400 has a 60gb vertex plus. It simply works.
Thu Jul 18, 2013 7:08 pm
