View unanswered posts | View active topics It is currently Thu Aug 17, 2017 2:20 pm
Reply to topic  [ 1 post ]
reduce windows 8 disk space usage
Post reduce windows 8 disk space usage
I parsed the list of packages disabled by default in windows 8 pro, so if anyone wants to remove all those unused features, just save this into a something.cmd file and run it as admin
if you are one to actually enable any of these, make sure you take them out of the list. I know I use hyper-v on my desktop, but not in the vm where i parsed the list of disabled features into commands for a batch file
DISM.exe /Online /Disable-Feature /Featurename:Microsoft-Hyper-V-All /Remove
DISM.exe /Online /Disable-Feature /Featurename:Microsoft-Hyper-V-Tools-All /Remove
DISM.exe /Online /Disable-Feature /Featurename:Microsoft-Hyper-V /Remove
DISM.exe /Online /Disable-Feature /Featurename:Microsoft-Hyper-V-Management-Clients /Remove
DISM.exe /Online /Disable-Feature /Featurename:Microsoft-Hyper-V-Management-PowerShell /Remove
DISM.exe /Online /Disable-Feature /Featurename:Printing-Foundation-LPRPortMonitor /Remove
DISM.exe /Online /Disable-Feature /Featurename:Printing-Foundation-LPDPrintService /Remove
DISM.exe /Online /Disable-Feature /Featurename:ScanManagementConsole /Remove
DISM.exe /Online /Disable-Feature /Featurename:LegacyComponents /Remove
DISM.exe /Online /Disable-Feature /Featurename:DirectPlay /Remove
DISM.exe /Online /Disable-Feature /Featurename:SimpleTCP /Remove
DISM.exe /Online /Disable-Feature /Featurename:SNMP /Remove
DISM.exe /Online /Disable-Feature /Featurename:WMISnmpProvider /Remove
DISM.exe /Online /Disable-Feature /Featurename:Windows-Identity-Foundation /Remove
DISM.exe /Online /Disable-Feature /Featurename:DirectoryServices-ADAM-Client /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-WebServerRole /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-WebServer /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-CommonHttpFeatures /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-HttpErrors /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-HttpRedirect /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ApplicationDevelopment /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-NetFxExtensibility /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-NetFxExtensibility45 /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-HealthAndDiagnostics /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-HttpLogging /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-LoggingLibraries /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-RequestMonitor /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-HttpTracing /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-Security /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-URLAuthorization /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-RequestFiltering /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-IPSecurity /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-Performance /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-HttpCompressionDynamic /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-WebServerManagementTools /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ManagementScriptingTools /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-IIS6ManagementCompatibility /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-Metabase /Remove
DISM.exe /Online /Disable-Feature /Featurename:WAS-WindowsActivationService /Remove
DISM.exe /Online /Disable-Feature /Featurename:WAS-ProcessModel /Remove
DISM.exe /Online /Disable-Feature /Featurename:WAS-NetFxEnvironment /Remove
DISM.exe /Online /Disable-Feature /Featurename:WAS-ConfigurationAPI /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-HostableWebCore /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-CertProvider /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-WindowsAuthentication /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-DigestAuthentication /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ClientCertificateMappingAuthentication /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-IISCertificateMappingAuthentication /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ODBCLogging /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-StaticContent /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-DefaultDocument /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-DirectoryBrowsing /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-WebDAV /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-WebSockets /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ApplicationInit /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ASPNET /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ASPNET45 /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ASP /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-CGI /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ISAPIExtensions /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ISAPIFilter /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ServerSideIncludes /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-CustomLogging /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-BasicAuthentication /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-HttpCompressionStatic /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ManagementConsole /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-ManagementService /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-WMICompatibility /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-LegacyScripts /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-LegacySnapIn /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-FTPServer /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-FTPSvc /Remove
DISM.exe /Online /Disable-Feature /Featurename:IIS-FTPExtensibility /Remove
DISM.exe /Online /Disable-Feature /Featurename:MSMQ-Container /Remove
DISM.exe /Online /Disable-Feature /Featurename:MSMQ-Server /Remove
DISM.exe /Online /Disable-Feature /Featurename:MSMQ-Triggers /Remove
DISM.exe /Online /Disable-Feature /Featurename:MSMQ-ADIntegration /Remove
DISM.exe /Online /Disable-Feature /Featurename:MSMQ-HTTP /Remove
DISM.exe /Online /Disable-Feature /Featurename:MSMQ-Multicast /Remove
DISM.exe /Online /Disable-Feature /Featurename:MSMQ-DCOMProxy /Remove
DISM.exe /Online /Disable-Feature /Featurename:WCF-HTTP-Activation45 /Remove
DISM.exe /Online /Disable-Feature /Featurename:WCF-TCP-Activation45 /Remove
DISM.exe /Online /Disable-Feature /Featurename:WCF-Pipe-Activation45 /Remove
DISM.exe /Online /Disable-Feature /Featurename:WCF-MSMQ-Activation45 /Remove
DISM.exe /Online /Disable-Feature /Featurename:WCF-HTTP-Activation /Remove
DISM.exe /Online /Disable-Feature /Featurename:WCF-NonHTTP-Activation /Remove
DISM.exe /Online /Disable-Feature /Featurename:NetFx4Extended-ASPNET45 /Remove
DISM.exe /Online /Disable-Feature /Featurename:Microsoft-Windows-MobilePC-Client-Premium-Package-net /Remove
DISM.exe /Online /Disable-Feature /Featurename:RasCMAK /Remove
DISM.exe /Online /Disable-Feature /Featurename:RasRip /Remove
DISM.exe /Online /Disable-Feature /Featurename:TelnetClient /Remove
DISM.exe /Online /Disable-Feature /Featurename:TelnetServer /Remove
DISM.exe /Online /Disable-Feature /Featurename:TFTP /Remove
DISM.exe /Online /Disable-Feature /Featurename:TIFFIFilter /Remove
also, if you don't use hibernation (I prefer to do it this way)
run the following from an admin command prompt
powercfg -h off
My windows 8 install in a VM is using only 9.4gb right now
another tip, to keep the OS size down, is run the following to cleanup old versions of OS dll files and what not periodically to keep it from getting too bloated after windows updates
dism /online /cleanup-image /startcomponentcleanup
there's also an option to cleanup windows update files in diskcleanup, this only cleans out the downloaded packages, so you may want to do both periodically
Thu Jun 27, 2013 11:17 pm
