View unanswered posts | View active topics It is currently Mon Aug 21, 2017 3:12 am
Reply to topic  [ 9 posts ]
File Server
Post File Server
So I am considering purchasing and constructing a file server, so ill ask for some input from all of you here:
GIGABYTE GA-D510UD - http://www.newegg.com/Product/Product.a ... 6813128436
WINTEC AMPX 2GB - http://www.newegg.com/Product/Product.a ... 6820161182
CORSAIR 400CX 400W - http://www.newegg.com/Product/Product.a ... 6817139008
Seagate Barracuda 7200.12 1TB - http://www.newegg.com/Product/Product.a ... 6822148433
SAMSUNG Spinpoint F3 1TB - http://www.newegg.com/Product/Product.a ... 6822152185
D-Link DGS-2205 10/100/1000Mbps Switch - http://www.newegg.com/Product/Product.a ... 6833127083
I remember some of you here previously running the non-raid versions of WD Blacks in raid, did any of you encounter any problems? Even thought i would be running the drives in a Raid 1 array for safety, i wouldnt want to get into any issues when using non-raid quality drives.
Lian-Li V2000+ II * LG 34UM95 * Custom Water Loop
Asus Maximus IV Extreme * 2500k 5GHz * 8GB Corsair Vengeance 1600
Asus GTX 660 * Asus Xonar DX * Beyerdynamic DT880 Premium * SeaSonic X-850w
Samsung 840 Pro 128GB * 2x Seagate 7200.12 500GB RAID0 * Windows 8 Pro x64
Thu Jun 03, 2010 8:24 am
Post Re: File Server
I don't see an NVidia card listed in there, so I'm leaving. :crying-blue:
Thu Jun 03, 2010 8:31 am
Hahaha, what would be the need for a card in a file server Comixion?
Thu Jun 03, 2010 8:35 am
Yes I know but still.
Just one being in there would make it highly prized possesion. ;)
Thu Jun 03, 2010 8:42 am
My server has a GT240!
Thu Jun 03, 2010 9:35 am
you don't really need that big of a power supply that system. you might look at something of a 250-300w, even something like that would be overkill. you could save a few bucks there
Thu Jun 03, 2010 9:43 am
Ya i know 400W is overkill, but there really arent any decently rated PSUs out there in the low Watt range sadly. This is the cheapest good one, and since it would be running 24/7/365 i was a PSU thats reliable.
Thu Jun 03, 2010 9:56 am
Talking with JD, started looking for an M-ITX case, most of em come with built in PSUs, came across this one, not many reviews thou
http://www.newegg.com/Product/Product.a ... 6811190113
Thu Jun 03, 2010 1:20 pm
Well i got my server delivered, and up and running.
Image Image Image Image Image
Sun Jun 20, 2010 7:33 am
