View unanswered posts | View active topics It is currently Mon Aug 21, 2017 3:13 am
Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
ITX Domain Controller
Post Re: ITX Domain Controller
Well that's one thing for Sandy Bridge then :)
Fri Jun 17, 2011 11:56 am
Well I went forth with it...
Though I must say, this Antec case is EXTREMELY disappointing. The I/O shield cut out seems to be off by about 5mm (maybe a bit less). There was rust in all the screw holes. The 80mm fan included has major bearing noise (you can hear it rattling/clicking).
One point of interest, the PSU inside the case is rated at 135W, but it is limited by the AC adapter which is only 65W. The 135W model of this case costs an extra $10 which as far as I can tell is just for the better AC adapter. I'm sure I could find it on eBay or something, but I don't need the extra power.
Fri Jul 08, 2011 2:20 pm
What are you planning to do with it mate?
Mon Jul 11, 2011 10:20 am
2pc & a biscuit?
Mon Jul 11, 2011 10:27 am
I guess nobody understands the enterprise side of the computer world...guess nobody has jobs in IT then.
Mon Jul 11, 2011 1:11 pm
The hell I don't....I watch Star Trek 3 times a week for the last 30 years.
Mon Jul 11, 2011 5:29 pm
I have studied active directory and linux servers in school but to be honest it was a b*tch, I don't dare giving someone who is personally still using it any advice. It has been quite a while and you probably know a lot more about it then I do now. Sorry for being of no use.
Sun Aug 21, 2011 3:41 am
Post server racks
server racks is very useful for offices works,
server racks
Wed Feb 22, 2012 1:47 am
Some recent upgrades:
-Intel Celeron G530
-ASUS P8H61-I
-Mushkin Enhanced Silverline Stiletto 2X2GB DDR3-1333
-OCZ Petrol 64GB
Image Image Image Image
Jam packed now! Even at 100% load, CPU temps peak at only 50C. Pretty damn good.
This makes my 3rd SB-based system. My desktop still has yet to get any platform upgrades...
Thu Mar 22, 2012 12:55 pm
Dialed down the voltage, running at 0.936V under load and 38W total power consumption and peaks at 43C.
Fri Mar 23, 2012 3:31 pm
