View unanswered posts | View active topics It is currently Sun Aug 20, 2017 9:18 pm
Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
ITX Domain Controller
Post ITX Domain Controller
Any thoughts? Plan to run Server 2008 R2 on it with the single purpose of being the domain controller. It'll be the primary server, then my Sandy Bridge system will be the 2ndary DC since it seems I have no luck with SB stuff and having my domain down results in uber slow bootup/logon times.
Gigabyte GA-E350N-USB3
http://www.ncix.com/products/index.php?sku=58835
Mushkin Enhanced Silverline Stiletto 4GB 2X2GB DDR3-1333
http://www.ncix.com/products/index.php?sku=55546
Crucial M4 SSD Micron C400 64GB
http://www.ncix.com/products/index.php?sku=60444
Antec ISK300-65
http://www.ncix.com/products/index.php?sku=39960
Comes to $354, plus taxes (less than I've spent on a P8P67 PRO and i5 2500K)
Mon Jun 06, 2011 3:24 pm
Post Re: ITX Domain Controller
Buiding servers can be quite inexpensive if you know what to get to get the job done. Well...that rules me out. :(
Mon Jun 06, 2011 4:54 pm
What might you use it for JD? Just another file server or a game server?
Wed Jun 08, 2011 2:58 am
Domain Controller...to run Active Directory.
Wed Jun 08, 2011 12:48 pm
So Server 2008 R2 OS resides on this HW? Pray tell then where do your HDs come into play? There are still in the same case you have now, right? I understand the principle, but a little confused as to the actual physical connections ... I can only assume it is via Ethernet cables. But you might want to draw us a picture so Comixion can fully understand what you're doing ... hehe.
Wed Jun 08, 2011 2:03 pm
You're over thinking things.
This will run Server 2008 R2 with Active Directory. My other server (the SB one) also runs Server 2008 R2 and has all my storage. I can live without storage for a few days of downtime, but since I have all my desktops joined to the domain, having my domain controller offline is an absolute bitch. It makes log in times around 5 minutes as it attempts to contact the domain controller.
Wed Jun 08, 2011 2:15 pm
Hell yea..you know I like pics.
Wed Jun 08, 2011 6:58 pm
Sounds very impressive JD, how come you have set it up like this??
Thu Jun 09, 2011 10:59 am
It's basically a small business setup in my house.... ;)
Just doing it for learning purposes really. They don't teach anything USEFUL in school, so I self-teach myself instead. I learn better that way anyhow.
Thu Jun 09, 2011 1:17 pm
Sounds even more impressive then :) What are you planning to do with the rig?
Thu Jun 09, 2011 1:34 pm
Why the SSD for a domain controller? What is causing your systems to take so long to boot? Your login credentials should be cached so you don't have to always connect to the domain controller.
Why not run virtual machines using Hyper-V or VMWare instead of adding another hardware node? Do you have $$ burning a hole in your pocket?
Tue Jun 14, 2011 5:23 am
Yes, I have extra money burning a hole in my pocket.
Yes, I run Hyper-V on my current server, but obviously when hardware fails, it fails even harder.
Yes, logins are technically cached, and I've even disable to wait for network via GPO and it still is piss poor login times when the DC is down.
SSD, well, it's only $50 more than a HDD really so why not?
Tue Jun 14, 2011 1:13 pm
Which one if I may ask.
Tue Jun 14, 2011 1:41 pm
Vertex are currently the best ones out there I think arent they JD/David??
Tue Jun 14, 2011 2:12 pm
I have the Crucial m4 C400 listed in the first post ;)
OCZ gimped the Vertex 2 in it's latest iteration but the Vertex 3 (for now) is a champ.
Tue Jun 14, 2011 2:19 pm
Geez I wish I could afford one of those. :(
Tue Jun 14, 2011 4:50 pm
The Vertex 3 is 6GBPS isnt it JD?
Wed Jun 15, 2011 6:14 am
Of course...SATA2 has reached its limits a long time ago ;)
Wed Jun 15, 2011 3:24 pm
How do you get around that??
Thu Jun 16, 2011 9:56 am
Sandy Bridge and AM3 both have native SATA3 support....
Thu Jun 16, 2011 1:01 pm
