View unanswered posts | View active topics It is currently Fri Jun 23, 2017 3:10 pm
potential server build
Post potential server build
so i've been soooo busy at work today, i had time to do some shopping, and since my tax return is coming, i came up with this list of options for a server
now i might be able to skip hard drives since i have some already, but i want better ones, so its a tossup there. and i may re-use the existing 2U case i have since it has 6 front removable drive bays which makes swapping out drives easier, even if its not hotswap bays. i'm definitely going to stripe a pair of SSD's though for teh OS. but here's the potentials.
--------MOBO--------REVISE
ASUS P8P67-M (REV 3.0) LGA 1155 Intel P67 - 130$
http://www.newegg.ca/Product/Product.as ... 6813131708
MSI P67A-G45 (B3) LGA 1155 Intel P67 - 140$
http://www.newegg.ca/Product/Product.as ... 6813130582
MSI P67A-G43 (B3) LGA 1155 Intel P67 - 135$
http://www.newegg.ca/Product/Product.as ... 6813130583
GIGABYTE GA-P67A-D3-B3 LGA 1155 Intel P67 - 110$
http://www.newegg.ca/Product/Product.as ... 6813128487
GIGABYTE GA-P67A-UD3-B3 LGA 1155 Intel P67 - 130$
http://www.newegg.ca/Product/Product.as ... 6813128476
--------CPU--------
Intel Core i7-2600 - 295$
http://www.newegg.ca/Product/Product.as ... 6819115071
--------RAM--------
Kingston HyperX Blu 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 - 87$
http://www.newegg.ca/Product/Product.as ... 6820104231
Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 - 83$
http://www.newegg.ca/Product/Product.as ... 6820226095
--------VGA--------
MSI N210-MD1G/D3 GeForce 210 1GB - 55$
http://www.newegg.ca/Product/Product.as ... 6814127515
--------RAID--------
3ware 9690SA-4I-SGL PCI Express SATA / SAS - 325$
http://www.newegg.ca/Product/Product.as ... 6816116065
3ware BBU-MODULE-04 Battery Backup Unit - 120$
http://www.newegg.ca/Product/Product.as ... 6816116087
3ware CBL-SFF8087OCF-05M 1 unit of 0.5m Multi-lane Internal SFF-8087 - 25$
http://www.newegg.ca/Product/Product.as ... 6816116097
--------DRIVES(x6)-------
Western Digital RE4 WD2003FYYS 2TB - 230$
http://www.newegg.ca/Product/Product.as ... 6822136579
Western Digital Caviar Black WD1501FASS 1.5TB - 110$
http://www.newegg.ca/Product/Product.as ... 6822136592
Western Digital Caviar Black WD2002FAEX 2TB - 170$
http://www.newegg.ca/Product/Product.as ... 6822136792
HITACHI Ultrastar A7K2000 HUA722020ALA330 - 220$
http://www.newegg.ca/Product/Product.as ... 6822145310
--------SSD(x2)--------
Mushkin Enhanced Callisto Deluxe MKNSSDCL40GB-DX 2.5" 40GB - 100$
http://www.newegg.ca/Product/Product.as ... 6820226168
Patriot Torqx 2 PT232GS25SSDR 2.5" 32GB - 100$
http://www.newegg.ca/Product/Product.as ... 6820220580
--------CASE--------
Athena Power RM-2U2260LV55 2U Rackmount Server Case - 170$
http://www.newegg.ca/Product/Product.as ... 6811192226
Thu May 05, 2011 9:04 am
Post Re: potential server build
My god...did you match all 5 numbers as well as the power ball?
Thu May 05, 2011 9:10 am
match the what?
Thu May 05, 2011 9:29 am
http://en.wikipedia.org/wiki/Powerball
Thu May 05, 2011 9:33 am
I don't think a i7-2600 will fit in a 1156 mobo. Just sayin.
Thu May 05, 2011 9:39 am
at most it only comes up to about 2800, its not bad
Thu May 05, 2011 11:14 am
that i7 is listed as being for that socket
Fri May 06, 2011 12:52 am
You better read again...
Sandy Bridge does not work on LGA1156 (P55 chipset). You need to look at LGA1155 boards with P67 chipset.
Fri May 06, 2011 2:33 am
crap, right socket, wrong chipset, ughr
Fri May 06, 2011 10:33 am
Personally I think an i7 for a server is a big overkill. I would rather go with
http://www.newegg.ca/Product/Product.as ... 6819103727 (I know it isn't as powerfull as the i7 but it should suffice plenty I think)
http://www.newegg.ca/Product/Product.as ... 6813130558 (has enough sata connections and isn't costly)
As for harddisks I myself have upgraded my server the day Saturday with these. Used to have the 500GB versions with 16MB cache.
I have it for private use tho, not all that much traffic, our needs might be different bit these drives save both energy and money.
http://www.newegg.ca/Product/Product.as ... 6822136765
Tue Jun 21, 2011 11:05 am
