View unanswered posts | View active topics It is currently Mon Jun 26, 2017 3:13 am
anyone have a color calibration tool that
Post anyone have a color calibration tool that
measures luminance data?
i have a basic model of spyder, which only does calibration, but it doesn't do the geeky stuff of showing you the luminance data and delta value.
Tue Mar 06, 2012 2:58 pm
Post Re: anyone have a color calibration tool that
Yes it does...all you need is the SpyderPro software ;)
I can PM you a key if you want to peek into the darkside.
Tue Mar 06, 2012 2:59 pm
lets email. i am on Gchat
Tue Mar 06, 2012 4:41 pm
so i found a piece of 3rd party calibration software that surprisingly works with my Spyder2 hardware colormeter. although the software is only a demo, it does allow me to do a few more calibration tests that's not available in the Spyder2 software. among them, the brightness/darkness uniformity test, which was what i was interested the most, as well as the color uniformity test across the screen. after running through all the tests... the Cinema Display has a screen uniformity of less than 16% error for darkness, and less than 11% for white, and less than 4% for tone. generally speaking less than 20% is considered VERY good, and less than 10% deviation is professional grade.
Wed Mar 07, 2012 9:06 pm
