View unanswered posts | View active topics It is currently Mon Jun 26, 2017 3:10 am
Few new USB3.0 pieces
Post Few new USB3.0 pieces
Since my Cosmos II has front USB3 ports, I figured I ought to put them to use. However, since my X58 board lacks USB3, I needed an add-on card.
Decided to try out a Mushkin USB3 flash drive as well. Rated at 60MB/s read 25MB/s write.
Fri Feb 17, 2012 6:46 pm
Post Re: Few new USB3.0 pieces
And some benchmarks using driver version 3.0.12.0.
USB3.0:
USB2.0:
Seems to live up to it's specifications and then some. It saturates USB2, and USB3 lets it shine. The Ventura Pro (rated at 120MB/s read, 70MB/s write) would be even better I'd say, but it's an extra $30.
The Ventura is also made of aluminum, so it has a quality feel to it, and the cap is able to snap onto the back for safe keeping when in use. It's a bit loose, but it holds.
Sat Feb 18, 2012 9:26 am
WD Scorpio Black 7200RPM 250GB
Tue Mar 13, 2012 5:06 pm
