View unanswered posts | View active topics It is currently Mon Jun 26, 2017 11:48 am
Reply to topic  [ 11 posts ]
Infamous red X
Post Infamous red X
Why does this thing always show on my network icon? Sometimes a red "x"...sometimes a yellow triangle. However I can connect to the internet. I have uninstalled and reinstalled the device and drivers. It does not affect me loggin into Origin but I do sometimes get the "you are offline" when I do try to login but I dont think thats the issue. because I have played online with the red x showing. But it is nonetheless annoying and I dont understand why its always there. Right now its the yellow triangle. Later, it will be a red x. I have googled the issue and tried everything but its not resolved. Is it in my SW? The onboard LAN or in the modem?
I'm gonna try a network card and see if theres a change.
Wed Dec 07, 2011 8:01 am
Post Re: Infamous red X
Solved.
Got an ethernet card. Disabled onboard LAN. Red X finally gone. Origin not fussy anymore.
Must have been maybe a faulty onboard lan, or drivers.
Wed Dec 07, 2011 11:00 am
... or the loose nut behind the wheel ... :mrgreen:
Wed Dec 07, 2011 11:06 am
i have a similar problem...every so often, i lose my connection, like HTTP or DHCP or something, cause i can still play games online, connect to steam, etc. but web browsers don't work...like if i open firefox, it doesn't even try to load my homepage, it just opens as a blank new tab...i reboot and it's good for another 12 hours or so...it doesn't do it in Ubuntu, just windows...so i know it's not my trusty DFI Blood Iron crapping out on me...
Intel Core2 Q9400 3.2ghz / DFI Blood Iron P35 T2RL / 8gb G.Skill DDR2 800mhz / ATI Radeon HD 5850 1gb / WD Black 500gb (SSD soon) / Antec HCG 620W / Antec 300 / Windows XP pro/7 pro x64/Ubuntu 12.04 / Samsung Syncmaster P2370 23"
Thu Dec 08, 2011 10:22 pm
I said "screw it" and plucked down for this. Best $60 I ever spent. Not an issue whatsoever and BF3 has been a breeze getting online. I figured while I have the $$ just get it. I had my doubts about but not anymore.
http://www.bigfootnetworks.com/killer-2100/
Thu Dec 08, 2011 10:41 pm
that's actually quite expensive for a network card, lol, but i want it for some reason...
Thu Dec 08, 2011 11:26 pm
Y'know, the Intel Gigabit CT adapter works just as well and is half the price...
Fri Dec 09, 2011 3:02 am
Dammit JD if you would have suggested that sooner I would have bought it. Now you owe me what.......about 30 bucks?. ;)
Fri Dec 09, 2011 9:35 am
That's what I'm using.
It offloads the network processing which is the same thing the Bigfoot card does, and I'd trust Intel for NICs over Bigfoot.
Thu Dec 15, 2011 7:41 am
Yes but Intel doesn't market it for consumer-gamer market ;)
Thu Dec 15, 2011 4:02 pm
Nonetheless I found an older PCI Netgear ethernet in my closet and it works fine. Have not had any Origin connection issues or even the dreaded red x. So I tookthe bigfoot back and got my $60 :mrgreen:
Thu Dec 15, 2011 6:19 pm
Users browsing this forum: No registered users and 2 guests
