View unanswered posts | View active topics It is currently Mon Jun 26, 2017 11:43 am
Reply to topic  [ 6 posts ]
Power Went Out, now i need a new Router
Post Power Went Out, now i need a new Router
Hey Guys,
Well my power went out a couple of days ago, and i guess my router died with it. So now i gotta get a new router, i had an old Wireless N Netgear router, that worked pretty well, but now im looking for a gigabit router with support for external storage, here are the models i was looking at, let me know which one is better, or if you recommend something better let me know :D
http://www.newegg.com/Product/Product.a ... 6833127215
http://www.newegg.com/Product/Product.a ... 6833124296
http://www.newegg.com/Product/Product.a ... 6833122326
Thanks
Fri Oct 29, 2010 11:40 pm
Post Re: Power Went Out, now i need a new Router
Do not buy the DIR-655. Absolutely shit.
I have a ASUS RT-N16. Very solid and running DD-WRT. Never used USB on it though, so not sure how well it works.
Sat Oct 30, 2010 1:20 pm
what netgear router do you have? i wonder if its really dead, could be worth trying to JTAG firmware?
Sat Oct 30, 2010 4:17 pm
Well after some extensive web searching i found that WNDR3700 is pretty good, i went and grabbed it, so far its pretty good, usb storage is working great, showed up right away on my network, i believe my old netgear is a wnr834b v2, its unresponsive, all the LEDs stay when you turn it on.
Sat Oct 30, 2010 10:11 pm
all the leds stay on? are you sure the router is dead and not the AC adapter? my old asus 520g router was doing the same kind of thing, the lan leds stayed on and it didn't respond, wasn't getting enough power from the AC adapter to boot. so i cut the plug and wired it to the 5v on my pc, because it was 5v, would be 12v otherwise and it worked. so i cracked the AC adapter open (what a pain) and replaced a bad capacitor, works fine
but i've recovered those netgear wnr834b v2's with dd-wrt via jtag too, they're easy enough, takes a while though.
obviously, i don't like spending money, i just make shit work, lol
Sun Oct 31, 2010 4:45 am
Yea i was thinking of getting a new router already, so its not too bad, just had to get one sooner than i had thought lol, ive already replaced my AC adapter, i got few at work and ill check to see if another one works
Sun Oct 31, 2010 12:17 pm
