View unanswered posts | View active topics It is currently Mon Jun 26, 2017 11:43 am
Reply to topic  [ 16 posts ]
Upgrade time!!!!!!!!!!!!!!!!!!!!!!!!!
Post Upgrade time!!!!!!!!!!!!!!!!!!!!!!!!!
Since I started working in the IT industry, I got the bug for enterprise hardware. I am still a noob, but decided to pull the plug and upgrade my infrastructure a bit. Currently everything is connected through an Asus rt n16 running tomato. Not going to lie, that thing is a beast. Tomato and ddwrt for that matter of fact have plenty of stuff one can play with. But since I wanted to play with Vlans and lacp, I ended up with a dell 5324 fully managed switch and a checkpoint utm edge that I'll use as a router and hopefully a vpn.
I ended up winning the eBay auction on this dell powerconnect for 35 bucks. Talk about a steal! One thing I noticed right away when I powered it up was the fans. Its got two 40mm fans that measured 65 decibels on an app. Not cool at all. What arrived yesterday was two low rpm fans that cost 30 bucks.
Now the issue I found was that Dell likes to play games. Those 3 pin fan headers are not the standard everyone uses. So, a quick repinning of the new fans resulted in this.
And bam!, powered it on to see if everything boots.
testing everything to make sure, it works.
Issue is that because these fans are lower volts, the switch intermittently sees the fans. Thus I get the fan led flickering from green to red. Also, getting logs with no fan, yes fan, no fan, yes fan.
But, its ok. After turning off, logging, everything is sweet and working.
Not to worried about air flow. I'm not planning on utilizing all ports, or maxing its super fast switching bandwidth. I'm looking at 5 or 7 ports here. :D Once I got everything done, I consoled into its interface, assigned an ip address on vlan1 and got the web gui running. Next upgrade, dual nic intel expansion card for the server. :D
Sun Apr 26, 2015 5:53 pm
Post Re: Upgrade time!!!!!!!!!!!!!!!!!!!!!!!!!
Summer upgrade:
Wifi on my asus rtn16 was going out. And with the 2.4GHz being saturated due to my neighbors, I said, go big or go home. So I took the bullet and ordered this enterprise grade access point. A UAP-PRO.
My cousin who works for TWC came over and properly installed it. We ran it behind the molding to the end of the wall. Popped a hole and fished it down the wall to the corner behind the tv where I put the switch and server. And best of all, no exposed wires.
Even at the mail box at the end of the drive way, I get full bars on the 2.4GHz. Suck it neighbors. :D
Fri Jul 24, 2015 6:48 pm
Nice, I really like Ubiquiti gear. I have their EdgeRouter Lite and getting the Pro model next week :D
Sat Jul 25, 2015 1:36 pm
I'm currently using an older checkpoint UTM appliance that needs to be replaced with something more powerful. I was debating between the edgerouter or just virutualize the router with pfsense.
Sun Jul 26, 2015 7:50 am
Got my EdgeRouter Pro all setup :)
I know...I know... I should really swap around eth0 and eth1 so the cables don't cross eachother :P
Fri Jul 31, 2015 5:33 pm
very nice. Hows the gui on it? Last I read on these, it doesn't compare to the cli.
Sat Aug 01, 2015 9:20 am
As of v1.7, it's pretty decent. They added a whole "config tree" view where majority of settings can be set without using the CLI, but not the most user friendly either.
What's wrong with CLI though? I did most of the setup over the console port actually.
Sat Aug 01, 2015 12:35 pm
Nothing's wrong with the cli. Just wanted to see how the gui is. My place of employment is Cisco based. The cli is our bread and butter. :mrgreen:
Sun Aug 02, 2015 12:26 pm
My TP-Link switch is very much like Cisco IOS, I suspect they might have just stole the code ;)
Ubiquiti's CLI is pretty easy to pickup though.
Sun Aug 02, 2015 5:26 pm
I see Ubiquiti launched some new AC AP's today: https://www.ubnt.com/unifi/unifi-ac Specs look pretty solid. Hopefully these ones don't overheat like their previous AC model.
Granted, I ended up buying a X-Claim Xi-3 a few weeks ago (built by Ruckus). Seems solid thus far, but it's a touch oversimplified. I mainly wanted VLAN-SSID mapping, and it looks like the few remaining features I want are coming in future firmware updates (RADIUS support namely).
Wed Sep 02, 2015 1:57 pm
the X-Claim is a pretty nice AP. Was looking at that as well, but its was a bit over my price range. While AC would be nice to have, I can live without the speed bump.
Talking about the range, I cut the grass the other week and listened to Pandora without any hiccups on the 2.4GHz. In the house, the 5GHz coverage is almost everywhere.
My next upgrade is to move the storage off the server on a dedicated NAS/SAN and convert the TS140 to an ESXi box. Thinking of a FreeNAS box with isci over dual or quad nics. This also involves creating a few vlans which should be exciting.
Tue Sep 08, 2015 11:02 am
Yeah, works well in my house, but I had to disable the auto-channel scanning. It hops channels way too frequently, so much so that it drops my Ecobee thermostat and Chromecast offline. Mounted it to the ceiling in the basement in the middle of the house. Not ideal... but it's close to all my network gear, and fishing a wire up through these walls is far too challenging.
My signal still drops off a ton going outside my house. Must be that old double-brick construction with wire mesh and plaster on top. Maybe I'll have to throw up an outdoor AP eventually :mrgreen:
Tue Sep 08, 2015 1:48 pm
That's the spirit. Get one on each corner of the house and call it a day. In the south, we have the exact opposite problem. Houses here are made out of paper mache and twigs. That's the reason I get roughly 10 wifi networks at any given time.
Tue Sep 08, 2015 5:10 pm
TWC Maxx just got here! My weak point right now is my router.
http://www.speedtest.net/my-result/4661282226
Sun Sep 13, 2015 3:20 pm
What speeds are you supposed to be getting?
Sun Sep 13, 2015 5:44 pm
200/20 is what they advertise on the webs. Like I said, my router is the weak link here. Its pretty much halved right.
Sun Sep 13, 2015 7:06 pm
