View unanswered posts | View active topics It is currently Sat Jun 24, 2017 11:35 pm
Reply to topic  [ 17 posts ]
Who has the most RAM?
Post Who has the most RAM?
I believe Avid6eek has 24GB of RAM or 16GB. I just ordered another 12GB of Mushkin Blackline DDR3 1600, which will put me at the max of 24GB (Triple Channel 6 x 4GB). Does any memory company make 8GB memory modules?
Fri Aug 26, 2011 2:24 pm
Post Re: Who has the most RAM?
What's the overkill limit on RAM anyways?
I have 8GB and heard that was quite enough. Is it not? Then I be gettin' more. ;)
Fri Aug 26, 2011 4:26 pm
12GB in my desktop, 16GB in my server.
Fri Aug 26, 2011 5:38 pm
It has been possible to go with a max of 32gb for a while i believe. But I would be slowing my system down with more than 4gb. The more memory you have the longer it has to search trough it to get what it wants. You should try to always have as little overkill as possible to be faster. (Busy)servers are a other thing however.
Sat Aug 27, 2011 1:24 am
I doubt that's true. Do you have any articles that explain why it would be so?
RAM is much faster than SSDs and especially HDDs so I can't see it making your system slower by having more of it. My computer surely didn't become any slower going from 6GB to 12GB.
Sat Aug 27, 2011 5:21 am
i think back in the old S939 AMD days, it used to be true due to the memory controller's weakness in unable to cope with large amount of RAM, as a result, it down clocks itself to handle the extra ram. but that is long gone. modern memory controller in both intel and amd all handle ram well. although i am not sure if it still limits your maximum overclock? anyone have first hand experience? i've filled all my slots with RAMS in my both intel i7 and C2Q system and they're both rock solid. and it performs way faster because windows can cache more.
the way window function is a lot different than other OS's. Windows, which is based on NT technology relies heavily on cache and virtual memory. the more memory and faster storage device you can give it.... the faster it'll perform.
Sat Aug 27, 2011 7:40 am
No, I haven't read any articles saying so. It is something my teacher IT-management taught. I don't know if he meant it the same way as BAM! or not, makes me doubt it a bit. Even so having more would't make it noticably slower offcourse, I think he was saying that overkill doesn't make it faster, and that if you had like WAY to much memory it would ultimately be slower. But it has been a while since I studied it, I can imagine it could have already been old news back then. I'll check it out later.
Sat Aug 27, 2011 7:49 am
Quote:
Everything in RAM has a memory location, and your CPU fetches the data from a memory location, so if there are many to search through, it will hinder your performance. But also having too few address (too little RAM) would be like taking the longest way possible to find the data, in other words it would have to access your harddrive to find the information.
This is pretty much what he said. It was also related to memory adresses and stuff.
Sat Aug 27, 2011 8:51 am
I'd say that information is extremely dated. With the speed and optimizations done on current-day CPU's, I don't see that being an issue at all.
Maybe back in the Pentium and Athlon era though ;)
Sat Aug 27, 2011 12:35 pm
And here I am thinking that my 4gb is overkill. :D
Mon Aug 29, 2011 3:01 pm
Hallejuha.....I can remove this paper bag off my head;)
Tue Aug 30, 2011 4:31 pm
actually my m1330 has 1GB. pretty fast with xubuntu installed
Thu Sep 08, 2011 5:41 pm
Is there any real advantage to running 1866 over 1600/1333 etc?
Fri Sep 23, 2011 3:42 pm
Yeah, MHz is much more beneficial than latency.
Fri Sep 23, 2011 5:04 pm
The only 2 on Newegg
http://www.newegg.com/Product/Product.a ... 6820211564
http://www.newegg.com/Product/Product.a ... 6820233218
Fri Sep 23, 2011 6:33 pm
you guys remember the good old DDR days of having timings of 2-2-2-5?
Sat Sep 24, 2011 4:00 am
16GB Desktop, 16GB Server. I can use the full 16GB on my server, but I don't come anywhere close on my desktop.
Tue Oct 04, 2011 9:16 am
