View unanswered posts | View active topics It is currently Fri Jun 23, 2017 9:55 am
JD..SSD plz
Post JD..SSD plz
I assume you know quite a bit about these. I'm quite the Novice on 'em. :oops:
Just point me to a nice one not too expensive but yet no crummy one. Just enough capacity to do the job. I don't store anything really. Just gaming. I'm currently using a 1TB WD Caviar Black.
Sat Jun 18, 2011 1:21 pm
Post Re: JD..SSD plz
I personally don't put any games on my SSD. It does absolutely nothing for them IMO.
I think you'd be fine with a 60GB, though they're typically slower. Larger capacity = faster due to having more flash chips that it can read/write from.
At this point in time, I'd suggest a Vertex 3.
Sat Jun 18, 2011 1:44 pm
thanks...mainly Windows
Sat Jun 18, 2011 3:09 pm
Yeah Windows, programs and benchmarks I run from the SSD :)
Everything else is on my RAID10 (games, music, photos, etc).
Corsair Force Series 3 would be a good choice too. Similar to the Vertex 3, but a bit cheaper I believe. There's also the Agility 3 and Solid 3 but they're slower than the Vertex 3, however more affordable too.
But all this is under the assumption of you getting the Z68 so you have SATA6. If you're not upgrading platforms, then you can get a Vertex 2 (make sure it uses 16 chips, not the gimped 8 chip ones) or C300 or C400/m4.
Sat Jun 18, 2011 4:17 pm
Ok...helpful info.
And yes I'm getting the UD5
Sat Jun 18, 2011 5:45 pm
This one has a rebate.
bueno?
http://www.microcenter.com/single_produ ... id=0364779
Sun Jun 19, 2011 1:21 pm
Should be good.
Sun Jun 19, 2011 2:49 pm
If you play single player games, level loading will be faster on an SSD. They are faster when loading multiplayer games as well, but then you just sit there and wait on the Celeron Noob.
Mon Jun 20, 2011 12:15 pm
I found it to be barely noticeable, but then again I've always ran my games off RAID5 and now RAID10...so I guess my read speeds have always been rather high.
Mon Jun 20, 2011 12:47 pm
Get the Intel X25-M. Its very reliable.
Tue Jun 21, 2011 2:57 pm
