View unanswered posts | View active topics It is currently Sat Jul 22, 2017 11:46 pm
Reply to topic  [ 14 posts ]
question about SSD
Post question about SSD
so i am preparing to buy a Crucial M4 to transfer all my stuff from my current boot drive to SSD, and hopefully with the included transfer kit, and StLouis's Winpe, I can migrate everything over without having to reinstall.
now. i noticed that my current setup BIOS doesn't have the drives in AHCI mode, i think it's currently in IDE. now. will changing that value to AHCI wipe out anything on my drive? as i understand that i need to change it to AHCI in order to run SSD correctly, so question is, should i change it before i migrate everything over to the SSD? or should i migrate everything over with the transfer kit and software first and then change the BIOS to AHCI.
Tue Apr 16, 2013 2:04 pm
Post Re: question about SSD
Just changing the setting in the bios to AHCI will cause the system to crash. You'll need to first edit a registry file, restart in bios and change the setting from IDE to SATA. I say first change the settings to AHCI on the HDD, make sure everything is working then migrate everything to the SSD. Here are the steps to change the setting to AHCI. http://forums.guru3d.com/showthread.php?t=313676
Tue Apr 16, 2013 2:35 pm
cool, thanks dog..
i also just found a similar guide here as well http://support.microsoft.com/kb/922976
i'll give those two links a read when i get home.
Tue Apr 16, 2013 2:37 pm
BAM! wrote:
cool, thanks dog..
yep, that's pretty much it.
Tue Apr 16, 2013 3:08 pm
it worked! and didn't crash. i changed the setting in the registry and changed the BIOS to AHCI, low and behold everything went fine. i just had to reboot twice. thanks dog!
Wed Apr 17, 2013 6:51 pm
i noticed that AS SSD can check whether TRIM and 4K Alignment is functioning correctly. can someone point how how to check with AS SSD? what to look for?
Thu Apr 18, 2013 10:48 am
ok.... what's this whole Msahci vs RST thing.... do i really need to install Intel RST? if it negligible different, than i won't bother. i am looking for maximum stability.
Thu Apr 18, 2013 1:28 pm
my understanding is that unless you're running them in a raid, you can live without the intel rst installed
Thu Apr 18, 2013 5:12 pm
I don't have it installed. Did not see the reason to have it. SSD seems to be working fine.
Fri Apr 19, 2013 6:43 pm
the only reason you might want it is trim, and like i said, i'm pretty sure you only need it for running ssd's in raid and trim wont work otherwise
there is a trimcheck tool if you want to be sure. easy enough to run it without the RST installed and make sure trim is working without it ;)
http://files.thecybershadow.net/trimcheck/
Fri Apr 19, 2013 11:25 pm
just a quick update.
got the drive yesterday. and after 3 hours of transfer time, i used the bundled transfer kit and software, it WOKRED!!!! everything transfered over and fired up. i used the default msahci and the transfer software did the 4K alignment for me. i did a quick bench and everything looked about right for a SATA 2 speed. sequential read/write are about 260MB/s each, and 4K are 21MB read, and 40MB/write which is on par with the results online. :)
i am super happy thanks so much for all the help guys..
so if you're using RAID SSD, intel RST is able to enable TRIM in RAID? is that it?
Sat Apr 20, 2013 7:51 am
not sure about raid, but I'm not running any kind of software for the SSD and TRIM is enabled in windows.
Sat Apr 20, 2013 2:08 pm
yeah, trim is enabled for me as well. there's a way to check trim in CMD. i am just curious if Intel RST can do trim in RAID, cause that'll be cool.
Sat Apr 20, 2013 2:28 pm
Certain chipsets with certain OROM versions can do RAID0 with TRIM. I think Z77 boards do by default, and X79 boards have been modified to support it as well (http://rog.asus.com/forum/showthread.ph ... IM-in-RAID!)).
Sat Apr 20, 2013 5:26 pm
