View unanswered posts | View active topics It is currently Fri Jun 23, 2017 8:24 pm
Reply to topic  [ 8 posts ]
Cable sleeving
Post Cable sleeving
Anyone ever done this themselves and how tough is it?
I wanna turn this
Into this
or just buy some :(
Sun Sep 25, 2011 5:50 pm
Post Re: Cable sleeving
It's rather time confusing and frustrating. You can do it, but you'll probably want to kill yourself when you're done, that is if your fingers even work anymore ;)
I'm sure you can buy pre-made extensions like that, but it'll probably cost a fair bit due to the amount of work involved.
Mon Sep 26, 2011 3:11 am
All of a sudden red doesnt look too bad
Mon Sep 26, 2011 5:30 am
the ATX connectors are a slut to take apart, i went through 3 different tools before i had one that did it succesfully while still being overly frustrating....that was a while ago, but still
Tue Sep 27, 2011 7:29 am
Ah ... I finally saw this thread. I tried sleeving and it hurt too much. It's better to buy them if you want to just do your own system. But if you want to make money doing it, then you need to learn to do it fast and painless ... :mrgreen:
Tue Oct 11, 2011 10:12 am
For me personally, that would require a fifth of Vodka, 4 vicodin, and a tube of Ben Gay. For each session. Per cable.
Tue Oct 11, 2011 1:03 pm
I'm glad you clarified that it was PER cable. Remind me NOT to have you do any personal sleeving for me ... :obscene-drinkingcheers:
Tue Oct 11, 2011 3:09 pm
I just wish they would leave out the fragrance. I'm tired smelling like and old fart.
Tue Oct 11, 2011 3:42 pm
