View unanswered posts | View active topics It is currently Tue Jun 27, 2017 4:56 am
Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
Loop done
Post Loop done
Just gotta get winders loaded. Some more crappy cell phones pics
Fri Jun 24, 2011 5:52 am
Post Re: Loop done
Whats it running at now?? If its not 5Ghz its not fast enough :D
Fri Jun 24, 2011 6:52 am
Post Re: Loop done
havent loaded the os yet...im out looking at ssd's but have yet to convince myself to get one considering what the dam things cost.
Fri Jun 24, 2011 7:22 am
Post Re: Loop done
I'd suggest getting two small (64GB) and run them off of your 6G SATA ports in a RAID 0 config. JUST the operating system ONLY!! All of your games and apps on something else. AND remember, always back up your data! BACK UP!!
Fri Jun 24, 2011 7:57 am
Post Re: Loop done
Allow me to show you a couple of things.
http://www.barefeats.com/ssd6g05.html
http://eshop.macsales.com/shop/SSD/OWC/Mercury_6G/
Fri Jun 24, 2011 8:27 am
Post Re: Loop done
Very nice ... will have to look into those ... nice indeed :handgestures-thumbup:
Fri Jun 24, 2011 8:55 am
Post Re: Loop done
If your not sure Comixion grab a couple Raptors that use the 2.5" drives, they are pretty darn good :) Got two of them sat here :)
Fri Jun 24, 2011 9:57 am
Post Re: Loop done
or check those out: http://www.newegg.com/Product/ProductLi ... rchInDesc=
Fri Jun 24, 2011 10:03 am
Post Re: Loop done
btw what made you decided to go with the swiftech's block.
Koolance's CPU 370 is right now arguably the best performing block. i am just wondering you could've gotten that. that' my next upgrade for my water rig, to swap out the Fuzion V2 for the CPU 370.
Fri Jun 24, 2011 10:05 am
Post Re: Loop done
Why is your GPU down there? That likely isn't a x16 slot.
And don't waste money RAID'ing SSDs. Buy the biggest you can afford. It'll be faster that way. Granted, $500 is a bit difficult to swallow for 240GB, but the performance will pay off.
RAID also negates TRIM support which could mean a shorter lifespan for the SSD (especially on Sandforce controllers I'd say).
Fri Jun 24, 2011 1:09 pm
Post Re: Loop done
Doesn't the same apply with this board? :think:
viewtopic.php?f=7&t=645&p=6337&hilit=pcie#p6337
Fri Jun 24, 2011 3:53 pm
Post Re: Loop done
http://forums.thecomputercabin.com/view ... pcie#p6337
Nope. Both physical x16 slots will run at x8 when there's a card in both. I'm not sure if it's smart enough to give the full x16 to that lower slot or not. My guess is that that lower slot only has 8 electrical lanes mapped to it, and when it detects a card in there, it disables 8 electrical lanes from the top slot.
Only the high-end platforms offer 2 electrical x16 slots ;)
Fri Jun 24, 2011 4:03 pm
Post Re: Loop done
What? I bought a crappy mobo? ;)
Yep,its something I was thinking about when I installed it but really didn't give a flip too much because it's was more convenient to put it there....I read Gigabytes site on that board and it says:
0.1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
0.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated with a PCI Express graphics card, the PCIEX16 slot will operate at up to x8 mode.
0.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1 and PCIEX1_2 slots. When the PCIEX1_1 slot or the PCIEX1_2 slot is populated with an expansion card, the PCIEX4 slot will operate at up to x1 mode.
It's doing fine but I'll move it up tomorrow. Not a biggie. Now I gotta buy shorter tubing. :mrgreen:
Fri Jun 24, 2011 4:08 pm
Post Re: Loop done
Yeah, really I don't think any cards saturate x16 PCIE2.0 slots anyhow. If your benchmarks seem similar, then I'd say there's no issue.
Sat Jun 25, 2011 2:26 am
Post Re: Loop done
Well I guess if it ever bothers me I can resolve the issue with
http://www.evga.com/products/moreInfo.a ... ly=GeForce 500 Series Family&sw=
Sat Jun 25, 2011 6:51 am
Post Re: Loop done
Your going the wrong way mate, more memory on your GPU's :D
Sat Jun 25, 2011 10:40 am
Post Re: Loop done
Elaborate plz. You referring to my last post or the previous one? Surely not the last one. Thats a great idea. :) And sorry for calling you shirley.
Sat Jun 25, 2011 11:40 am
Post Re: Loop done
That's a sweet PC you've got there. So if I were to send you a $100 bill in the mail, what address would I have to write on the envelope?
Problem?
Sat Jun 25, 2011 3:41 pm
Post Re: Loop done
What do your $100 bills look like? Hold it up to the light.
Sat Jun 25, 2011 3:49 pm
Post Re: Loop done
Problem?
Sun Jun 26, 2011 9:59 am
