View unanswered posts | View active topics It is currently Wed Aug 16, 2017 10:38 pm
Reply to topic  [ 8 posts ]
Single sleeving
Post Single sleeving
I like. JD, where did you get that done on your PSU? I want to get that done on mine as well as my X-FI front panel cables.
Sat Apr 30, 2011 7:10 pm
Post Re: Single sleeving
I just buy extension cables ;)
And it's definitely not worth paying somebody to do it. Cost you a fortune. Better to learn how to DIY.
Sat Apr 30, 2011 8:59 pm
Linky please
Sun May 01, 2011 5:49 am
http://www.performance-pcs.com/catalog/ ... ath=34_804
Sun May 01, 2011 6:06 am
Thanks JD.
Where have these things been all my life? these are so clean looking.
a few more items I ordered today for my upcoming project.
and why is performancepc so dam slow? I bet I count 15 seconds between pages :cry:
http://www.performance-pcs.com/catalog/ ... e997ab0dc1
http://www.performance-pcs.com/catalog/ ... s_id=28907
http://www.performance-pcs.com/catalog/ ... s_id=28909
x2
http://www.performance-pcs.com/catalog/ ... s_id=28905
http://www.performance-pcs.com/catalog/ ... s_id=25912
Have not decided between white,red,or uv. whatever makes the red tubing look decent.
http://www.performance-pcs.com/catalog/ ... 29d889c3a2
Sun May 01, 2011 4:01 pm
I'd say get the tubing in hand first, then decide on lighting.
Or buy UV, Red, and White lighting and just try each one! ;)
Sun May 01, 2011 5:03 pm
And have more bits.... ;)
I have some red tubing on hand. I put an led flashlight to it to get the idea. It seemed more red than what uv shows, which is more of an reddish-orange.
oops..and I almost made a big mistake. I noticed i have 2 of the 8-pin vga extensions in my cart. The 580 of course is 8-pin...6-pin :mrgreen:
I have not hit the submit button just yet...phew
Sun May 01, 2011 5:17 pm
Gosh....I just noticed I ordered 2x 6-pin VGA cables in addition to the 8-pin.
I accidently put a "2" in the box I guess. :cry:
Now I have no choice but to buy an 8-pin and another hydro-copper 580. :mrgreen:
Somebody loan me $700
1 x Lamptron Elite Aluminum Reusable 3/4" OD Liquid Tubing Clamps - Anodized Red $3.99
4 x *** NEW *** Enzotech High Flow 1/2" Barb Fitting G 1/4 Thread - Matte Black $13.96
1 x XSPC RX360 Extreme Performance Radiator
- Nozzles: No Nozzles $84.95
1 x *** NEW *** NZXT CB-24P Single Sleeved M/B 24Pin - Red $9.99
2 x *** NEW *** NZXT CB-3F Single Sleeved 3-Pin Fan Extension 12" - Red $9.98
1 x *** NEW *** NZXT Single Sleeve 8pin to 8pin Video Extension - Red $5.99
2 x *** NEW *** NZXT Single Sleeve 6-Pin VGA (PCI-Express) Extension 10" - Red $11.98
1 x *** NEW *** ModRight CableRight Single Braid M/B 8-Pin to 4+4 12V EPS Extension - Red $7.99
5 x Feser Tube Active UV Hose - 1/2" ID (3/4"OD) Anti-Kink Tubing - UV Red $13.75
Sub-Total: $162.58
United Parcel Service (1 x 8.55lbs) (2nd Day Air): $38.29
Total: $200.87
Mon May 02, 2011 1:14 pm
