View unanswered posts | View active topics It is currently Wed Aug 16, 2017 10:43 pm
Reply to topic  [ 8 posts ]
NZXT Sentry LX
Post NZXT Sentry LX
http://www.newegg.com/Product/Product.a ... -_-Product
I pulled it.
The one thing I don't like about it is you cannot get the maximum RPM's out the fans. Fans that are rated for 2000rpm will max out at only 1700rpm. Fans rated at 1000rpm max at 600-800rpm etc. This has been a problem with it from others as well.
I'm going with something more simple.
http://www.lamptron.com/products/view/F ... ller_FC5V2
Mon Apr 11, 2011 5:20 pm
Post Re: NZXT Sentry LX
All fan controllers do this as they don't have 100% efficiency so 12V in doesn't mean 12V out. Some of the voltage is loss to heat, powering the circuity and LCD screen, etc.
Unless it steps up the voltage to 13V or so, you won't get a full 12V for your fans.
Tue Apr 12, 2011 2:10 am
With the NZXT said to have only 5 watts per channel and the Lamptron stating to have 30 watts per, I;m assuming this would fix the issue?
Tue Apr 12, 2011 6:25 am
Not at all. Though the whole point of a fan controller is to run at less than 12V anyways to make your fans quiet
Tue Apr 12, 2011 6:58 am
i used to use fan controllers a lot, but later disposed them because now adays you can pretty much control them through the motherboard and set it up automatically. they just take up too much space and god i hate the wiring mess it creates.
Tue Apr 12, 2011 8:21 am
Unless of course you like to sleeve your wiring ... then it's not so bad! :ugeek:
Tue Apr 12, 2011 12:36 pm
That's where your cable management skills needs to come to the surface.;)
Tue Apr 12, 2011 4:09 pm
i guess i must've fell asleep in that class.
Tue Apr 12, 2011 5:19 pm
