View unanswered posts | View active topics It is currently Fri Jun 23, 2017 8:25 pm
Reply to topic  [ 8 posts ]
mATX cases?
Post mATX cases?
does anyone know of a micro ATX case with the psu at the bottom? i think i might put the mATX board back in my hackintosh since i don't need the full board as im using an external soundcard. that way i can shrink the box down some. my monitor sits on top though, so a top vent isn't important, and will be restricted if its there
Sun Mar 27, 2011 4:54 am
Post Re: mATX cases?
not gonna lie, but im thinking about it
http://www.newegg.ca/Product/Product.as ... 1129041CVF
Mon Mar 28, 2011 8:25 am
http://www.newegg.ca/Product/Product.as ... -_-Product
:mrgreen:
Mon Mar 28, 2011 9:30 am
way too big, im looking for microATX, not another giant desktop.
ill forgive you for not reading my post under the assumption you didn't have your glasses there old guy ;)
Mon Mar 28, 2011 11:29 am
It's not that big. Not like it's big brother. And yes...my glasses are smudged up. ;)
Mon Mar 28, 2011 11:50 am
That mini-P180 isn't much smaller than an ATX case...
Mon Mar 28, 2011 2:10 pm
i noticed that earlier when i was checking out the measurements, its almost the same size as the p150 the system is in now
Mon Mar 28, 2011 4:38 pm
so i found a case, and ordered it, this is it
http://www.in-win.us/products_pccase_se ... del_id=249
i also ordered this
http://www.newegg.ca/Product/Product.as ... 3166073CVF
its all for the DJ box, im going to have a bit of hardware swapping to do as well, but this should cut down the size significantly anyway. i need to find a capable cpu heatsink that fix in the new case though
oh, i've also got a pair of these hooked up right now, so far the learning curve with them is a miserable fail though, but if at any point i think i might want to call myself a DJ, i want to semi be able to analogue mix. though i'm playing an opening slot at a club in 2 weeks, on the 15th......i'm worried
http://www.zzounds.com/item--DENDNS3000
Sat Apr 02, 2011 7:05 pm
