View unanswered posts | View active topics It is currently Mon Jun 26, 2017 8:14 am
Reply to topic  [ 6 posts ]
Nob in waterloop
Post Nob in waterloop
When I just looked in my case after moving it and having pushed a cable correctly in place...
I noticed that one part of the loop was squished together. Thought my heart skipped a beat, this is my first WC setup so I'm not sure on what to do.
For now I taped it to keep it in shape, any advice for this scenario (without rebuilding it) ?
Tue Nov 01, 2011 4:31 am
Post Re: Nob in waterloop
Swished? As in kinked?
You can just use some zip-ties to make the tubing stiffer and get rid of the kinks.
Tue Nov 01, 2011 6:05 am
Kinked that was the word I was looking for!! Thanks for the advice I'll try it first thing tommorow
Tue Nov 01, 2011 10:33 am
Solved, not beautifully but solved non the less. Idle is still at 27-29C
Wed Nov 02, 2011 6:40 am
In the future, I'd say either buy tube coils or use some 45's or 90's to reduce the bending in the tubing. Then it'll look better :)
Wed Nov 02, 2011 7:36 am
The kink is just moving now... already fixed it a few times this way :(
Fri Nov 04, 2011 11:37 am
