View unanswered posts | View active topics It is currently Tue Aug 22, 2017 9:49 am
Reply to topic  [ 9 posts ]
Need recommendations on 120mm case fans.
Post Need recommendations on 120mm case fans.
I'm thinking about replacing my stock case fans on the Cosmos 1000. Any suggestions for someone who's looking for silent operation? Although silence is preferred, I definitely want to make sure I'm getting the best airflow.
I'm looking at all the 120mm cases listed at amazon.com, but don't know what to look for other than the obvious titles of "silent". Oh, and no LED-lit fans. No need for them since the cosmos 1000 is designed for minimalists.
Case: Cosmos 1000 | PSU: Corsair 750TX | O/S: Windows 7 Pro 64-bit | CPU: Core i7 920 w/ Corsair H80 Liquid Cooler | Mobo: Asus P6T Deluxe | RAM: Corsair Dominator DDR3 1600 6GB | HDD: (2x) WD Cavier "Black" 640GB | RAID 0 | Sound Card: Asus Xonar D2X | GPU: EVGA GTX 580 SC DS | Monitor: Dell Ultrasharp U2711 | Speakers: Logitech Z-5500 5.1 THX | Mouse: Logitech Performance MX | Headset/Mic: Logitech G35 7.1
Thu Sep 22, 2011 12:40 pm
Post Re: Need recommendations on 120mm case fans.
I would go with Noctua or Gentle Typhoons.
Thu Sep 22, 2011 4:23 pm
I think I'll go with the Noctua brand. Hmmm...just wondering if there is a way to check my case fan rpm's so I can compare it to the ones I'm planning to get. Is there a way?
Fri Sep 23, 2011 5:48 pm
I love the Noctuas design as far as function. I just have to get past the cream blades.
Fri Sep 23, 2011 6:08 pm
Plug them into your motherboard headers?
Fri Sep 23, 2011 8:07 pm
Noiseblockers, they come at 1200RPM and 2000RPM I believe.
Sat Sep 24, 2011 2:38 am
I'm thinking about getting this: Noctua NF-S12B FLX - Case fan - 120 mm
http://www.amazon.com/NF-S12B-FLX-Setti ... 806&sr=8-4
Think it's a good choice ?
Sun Sep 25, 2011 9:37 am
Dtech ... you can't go wrong with the Noctua brand of coolers or fans. I have used Noctua fans since they first came out. I also like the Silverstone Air Penetrator 120mm case fans. :handgestures-thumbup:
Mon Sep 26, 2011 7:21 pm
AP's are a bit noisy compared to Noctua's though...
Mon Sep 26, 2011 7:32 pm
