View unanswered posts | View active topics It is currently Mon Jun 26, 2017 8:16 am
Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
HAF X Radiator/s placement
Post Re: HAF X Radiator/s placement
jdrom wrote:
RX360 is better built and dual-pass. More surface area = better cooling and higher thermal capacity.
If it'll fit in the case, buy it.
Ok then. It's an 800D so I should assume it would.
Wed Apr 27, 2011 5:48 pm
What about a Silverstone case Comixion?? They would hold I think 2 triple rads and allow for a few more as well..
Also I dont bother with any of the Feser coolants anymore, I just get the distilled water now and throw that in, plus it costs like £1.50 for 2.5 litres of the stuff.. Just then buy the colour tubing you want and jobs a gooden :) Also it wont stain the pipes and res to shite either, it can get a right sodding mess.
Also have you considered adding a drain Comixion??
Wed Jun 08, 2011 2:44 am
Now I have to agree with you Phill on your suggested use of Silverstone cases. I use them exclusively since my QX9770 build (ASUS Rampage Extreme LGA775) in the Temjin T9 case. My i7 sits in the Fortress FT02 BW. Plus I use their coveted power supply units as well. :handgestures-thumbup:
Wed Jun 08, 2011 8:47 am
They are great cases, expensive, but then you do get what you pay for. I did look at one for myself, but it just wont fit everything in I'd like to so I sheered away from them. Worth a look mind :D
Wed Jun 08, 2011 8:55 am
Somebody mentions silverstone and you decide to chime in. ;)
And well, I forgot the drain. Right after I was done putting in the coolant. :(
Wed Jun 08, 2011 10:39 am
Get one :D When you take it apart next time you'll thank everything that is near to you for having it!! :)
Wed Jun 08, 2011 11:48 am
My wife is still pissed from the last time I drained it. There's a nice red blotch on the floor. :(
Wed Jun 08, 2011 7:00 pm
Was it anything like last time with the broken pipe?? :D :lol:
Thu Jun 09, 2011 10:46 am
Not near as widespread. plus water is clear.
Thu Jun 09, 2011 12:17 pm
:lol: :D
Thu Jun 09, 2011 12:36 pm
