View unanswered posts | View active topics It is currently Mon Jun 26, 2017 8:15 am
Reply to topic  [ 12 posts ]
Tubing brands
Post Tubing brands
What's the cosensus on Primochill clear tubing as opposed to the Tygons, Fesers etc? There are so many opinions out there that you don't know what to believe except find out for yourself. Some clear tubing can look cloudy.
In addition, can you add additional UV dyes to Feser 1 premixed coolant without it causing harm? Feser 1's UV properties are poor compared to otheres I've seen.
Thu Apr 21, 2011 9:48 am
Post Re: Tubing brands
I believe Feser says to only use their dye if you need more.
And all clear tubing clouds IMO. But they all start off clear. Really should just buy colour tubing though over relying on coloured fluid.
Thu Apr 21, 2011 12:56 pm
The thing about Feser Tubing "red" is that it looks orange...very orange and I hate orange so I wanted to try the clear with either Distilled water and dye, or the feser 1 UV red coolant.
I see first hand that the Feser1 coolant is much "redder" than the red Feser tubing. And Ive now read that Primochill is a good quality tubing so it's looking more like that and distilled water and dye.
Or just do yard work.
Thu Apr 21, 2011 2:12 pm
Yeah I've always used Primochill ProLRT. Clear and now UV Blue. No issues.
The UV Blue does look purple in direct sunlight though, but otherwise it's blue and glows nicely under UV.
Thu Apr 21, 2011 5:09 pm
What are you using for coolant?
Also if you use Dist. water and want to dye it and have the coolant UV reactive whats the ideal solution?...and is it still a good idea to use an addative?
Thu Apr 21, 2011 5:34 pm
I use Mustkleer stuff (I always get the spelling wrong mind) but I get it in 7/16" sizes so its a tight fit over the 1/2" barbs I use so then I dont have to use any clamps or shite :)
Wed Jun 08, 2011 2:47 am
Yea I used the 7/16 on 1/2 barbs. I had to use muscle and sweat to get it on but it stays there. And dam hard to remove. I hate the ugly clamps myself.
Wed Jun 08, 2011 7:31 am
Well the easy way around that is to put the ends in warm water and to put them on then. Softens the ends so its easier to put it on :)
Wed Jun 08, 2011 7:43 am
Yep..did that. Along with a little saliva.
Wed Jun 08, 2011 7:53 am
Never needed the saliva bit but works well if you leave it in there for a little bit :)
Wed Jun 08, 2011 7:58 am
I was afraid I was gonna get the saliva in my loop and corrode it. :mrgreen:
Wed Jun 08, 2011 11:14 am
Dont spit so much next time!! :lol:
Wed Jun 08, 2011 11:46 am
