View unanswered posts | View active topics It is currently Mon Jun 26, 2017 8:10 am
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3
eVGA Hydro Copper 2
Post Re: eVGA Hydro Copper 2
Basically mate, their nickle blocks have issues with them pealing inside and causing problems.. Not the best of things sadly.. I think a quick google might help find out :)
Thu Jun 09, 2011 12:34 pm
Mainly if you use distilled water with silver coil though from my understanding.
If you run pre-mixed coolants that have anti-corrosion stuff in them, it should last longer.
Thu Jun 09, 2011 1:21 pm
I think it didnt matter according to what I was reading, I'll see if I can dig it out for your guys tomorrow :)
Thu Jun 09, 2011 1:35 pm
I have read so many articles going back and forth on Distilled water and Pre-mixed coolants. It seems 50/50
Thu Jun 09, 2011 1:40 pm
There's the link I said about guys :)
http://www.ekwaterblocks.com/index.php? ... eturnid=17
I hope that helps :)
Fri Jun 10, 2011 11:14 am
Quote:
1. Certain chemical additives based on pure silver and Copper Sulphate that were added to the loops all of these cases have made distilled water electrolytic and with its properties they caused corrosion of nickel plating.
See, pretty sure it's mainly targeted at those who use Distilled + Silver Coil. At least from EK's testing.
I know forum reports vary wildly and likely people lying (or not telling the full truth) about their issues too.
Fri Jun 10, 2011 12:59 pm
I'm glad I bought a Swiftech so I know my 580 will last longer than JD's :mrgreen:
Fri Jun 10, 2011 2:55 pm
I'm going for the Aquacomputer blocks, as I have a few things that wont fit unless I do that :D :lol:
Sat Jun 11, 2011 1:51 am
