View unanswered posts | View active topics It is currently Tue Aug 22, 2017 9:48 am
Reply to topic  [ 9 posts ]
Lamptron Elite Aluminum Clamps
Post Lamptron Elite Aluminum Clamps
Say goodbye to ugly clamps.
Wake the kids and phone the neighbors.
These are neato. Clean looking and less likely to pinch or cut your tubing.
http://www.lamptron.com/products/view/E ... ing_Clamps
http://www.performance-pcs.com/catalog/ ... s_id=30172
hmm..didn't someone point these out? :think:
Mon Apr 11, 2011 4:48 pm
Post Re: Lamptron Elite Aluminum Clamps
Yes, I did :)
Tue Apr 12, 2011 2:08 am
I chimed in on those as well ... :handgestures-thumbup:
Tue Apr 12, 2011 12:33 pm
Let me take this time to chime in on the advantages and disadvantages of these clamps since I have used them now.
pros: dam good looks
choice of colors
ease of use
cons: expensive--but who cares? huh?
Aluminum--not a good thing for clamps, no matter the pressure
poor (weak) threading design
Of the 8 I bought at 4 bucks a pop, 3 were bad. Not good when $12 went to pot. So I had to use conventional clamping on my Hydro Copper and CPU. The threading for the screws were stripped before I used them. I tested each one first. It's not a good idea to drill such a small (threaded) hole into aluminum. Ever. It just will not last. They should be a harder type of metal.
If these were a quarter a piece it would be no big deal since water tubing doesnt need such pressure applied to the clamps. Just thought I would let you know. But overall they are an nice touch over conventional "ugly" clamps. For watercooling I would buy them again and hope I get all good ones.
Mon Apr 18, 2011 5:17 pm
if you got extras.. can use it as wedding band. save a trip to the jewlry store for your wife.
Mon Apr 18, 2011 5:59 pm
lol..or maybe a mood ring.
Mon Apr 18, 2011 6:20 pm
Stupid question here but why do you need them?
Wed Jun 08, 2011 2:48 am
Well I don't need these particular clamps for sure. They don't tighten shit. I only used 2 at the res. I can see using something on the 1/2ID tubing just for piece of mind but the 7/16ID when fitted onto the 1/2" fittings fits pretty dam snug.
Wed Jun 08, 2011 7:27 am
Its the only stuff I use because of it :) Drives me nuts having to put ugly clamps on things :(
Wed Jun 08, 2011 7:41 am
