View unanswered posts | View active topics It is currently Mon Jun 26, 2017 8:11 am
Reply to topic  [ 1 post ]
Coolermaster Vortex plus
Post Coolermaster Vortex plus
I just bought a cooler master vortex plus today to test a xeon 5570. I had an intel 2u server heatsink but it wouldn't fit the board because of the capacitors around the socket
all i can say, is the intel mounting brackets with this cooler master heatsink are terrible. don't buy it if you plan on putting it on an intel board.
for the AMD side it uses the standard amd mounting bracket which should be fine
Sat Jan 19, 2013 1:09 pm
