View unanswered posts | View active topics It is currently Fri Jun 23, 2017 11:35 am
Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4  Next
i7-2600K
Post Re: i7-2600K
I would mate, he said in another thread his 580 isnt as fast as it was in his i7 rig!! :lol:
Tue Jun 28, 2011 3:50 am
Post Re: i7-2600K
Yep...891 core is all she will do now. With the cpu @4.5.
The i7-920 @4.3 on the Asus board I had the 580 at 970 core.
Tue Jun 28, 2011 6:50 am
Post Re: i7-2600K
That just seems odd to me Comixion... What have you done to it?? :lol:
Tue Jun 28, 2011 7:45 am
Post Re: i7-2600K
I pissed it off because I took it's mother away. ;)
I'm gonna clock it nice and slow like....maybe try using the same 270.xx drivers I was using before.
Tue Jun 28, 2011 7:59 am
Post Re: i7-2600K
I been diggin. The Gigabyte UDX series and USB 3.0
There are two ways that our USB/SATA 3.0 works: one way is Turbo mode where it uses PCI-E lanes to communicate directly with the CPU for best performance. The other way is through the P55 chipset where it is limited to PCI-E gen 1 speed (2.5Gb/s) – when turbo mode is disabled. The point is that Gigabyte P55A boards are all about options: we provide options for the user to decide if he wants 5Gb/s SSUSB for high-speed backup or if he prefers SLI/CFX while still enjoying USB/SATA 3.0 – albeit at a lower speed. And in auto mode the system will decide for the user, i.e. if there is a 2nd VGA card then SLI/CF takes precedence, but if there is only 1 VGA card and a device is plugged into a USB/SATA 3.0 slot then superspeed data transfer takes precedence.
Just a couple of numerous topics on the subject:
It looks like this problem is unique to Gigabyte's implementation of usb 3.0+.
Wow just figured it out i was looking through other forums of people with the same issues and in one of them someone suggested to disable the USB 3.0 Turbo Mode because it uses some of the pipelines and after doing that everything was fixed!!!
Wed Jun 29, 2011 10:02 am
Post Re: i7-2600K
WARNING!! This is an official alert from the Administrator of this forum!!!!
Start a new thread or this thread will be deleted!!... this thread is for i7-2600k processors only!!
:angry-tappingfoot:
Wed Jun 29, 2011 11:10 am
Post Re: i7-2600K
Sooo, ... you're convinced that it was the mobo and the PCI-e lane slowing down your GPU?
Wed Jun 29, 2011 11:21 am
Post Re: i7-2600K
Sorry I can't answer that question because I was warned to discuss this in another thread. Besides...Phill started it. :mrgreen:
Wed Jun 29, 2011 11:40 am
Post Re: i7-2600K
lets just get even more off-topic. when will a hexacore 1155 cpu come out. i am running outta patience.
Wed Jun 29, 2011 12:02 pm
Post Re: i7-2600K
So BAM! ... what's your thought on the new Dodge "Challenger?"
EDIT: "It's my forum and I can do what I want!"
Wed Jun 29, 2011 12:27 pm
Post Re: i7-2600K
Likely never. LGA1155 is not a high-end platform and as such 6-cores have no purpose on it.
And generally speaking, the home user doesn't need more than 4 cores w/ HT anyhow.
Wed Jun 29, 2011 12:53 pm
Post Re: i7-2600K
that's what we said few years ago when first Athlon X2 came out. but games becomes more advanced, and demanding, so are softwares and encoding packages.
Wed Jun 29, 2011 12:55 pm
Post Re: i7-2600K
I LOVE IT!!.. i actually thought of trading in my Charger SRT for a Challenger SRT, but scraped that idea when i saw the 2011 Mustang GT 5.0.
Wed Jun 29, 2011 12:57 pm
Post Re: i7-2600K
Yeah, but I don't think LGA1155 will ever see six-core. Just like S754 never saw dual-core, instead AMD came out with S939. In this case, Intel has their LGA2011 platform coming out which will likely have 6 or 8 core CPUs.
Wed Jun 29, 2011 1:00 pm
Post Re: i7-2600K
More info
With Gigabyte boards that have uSB 3 and SATA 6 capability, there are limits or bottleneck when running SATA 6 and USB 3. In particular, with the Gigabyte chipset when you use Turbo SATA3 / USB3.0 enabled in BIOS setup, 1st PCIex16 slot will run at x8 bandwidth and 2nd PCIex16 slot will be disabled.
1366 boards experience no limitations on PCI-E GFX lanes when SLI or XFire is added and remain at x16 speeds
1156 boards drop to x8 on the PCI-E GFX lane
The Asus 1156 Boards do not suffer from that problem.
Thu Jun 30, 2011 6:17 am
Post Re: i7-2600K
Are you convinced now that you should have waited on the upgrade? ... LGA2011 is looking better and better for the high-end enthusiast. I believe the X79 chipset will be far more robust than the Z68 will ever be ... :ugeek:
Thu Jun 30, 2011 6:32 am
Post Re: i7-2600K
Well...when it gets here I will let you know. ;)
Thu Jun 30, 2011 7:13 am
Post Re: i7-2600K
More info
That was with 1156 ;) SATA6 is built into the Intel chipset now and only USB3 should be a 2ndary PCIE controller. IMO you can disable USB3 as it has no purpose currently and you likely don't need more SATA ports than what the Intel chipset provides.
Thu Jun 30, 2011 12:27 pm
Post Re: i7-2600K
do you guys mean 1155?
1156 is P55 like i7 870
Thu Jun 30, 2011 1:15 pm
Post Re: i7-2600K
Yeah, well, Intel didn't think straight when it did the 1156 platform ... short-lived and probably a big waste of time ... :doh:
Thu Jun 30, 2011 2:12 pm
