View unanswered posts | View active topics It is currently Fri Jun 23, 2017 11:32 am
Reply to topic  [ 2 posts ]
CPU fan error message
Post CPU fan error message
Meh...it's annoying.
Ever since I unplugged the HSF it gives me that warning on boot. Is there a way to disable it?
Tue Apr 19, 2011 9:44 am
Post Re: CPU fan error message
usually in the bios, where the fan settings are. you can turn off the temp sensor. although not all boards can do that tho.
Tue Apr 19, 2011 10:29 am
