View unanswered posts | View active topics It is currently Fri Jun 23, 2017 11:38 am
Poll: what power option do you have set in Win7
what power option do you run on your desktop
Balanced 50%  50%  [ 3 ]
High Performance 50%  50%  [ 3 ]
Total votes : 6
Post Poll: what power option do you have set in Win7
i am just doing a poll on what power management option you guys all use on yoru i7, i5's for DESKTOP.
i noticed the other day that my desktop apparently was on "high performance". it explains why it was very often stuck in peak clock speed 4.8ghz, and seldom drops to 1.6ghz; although it does drop when there's no activity. i changed to "balanced" and it now drops to 1.6ghz more often, and speeds up to 4.8ghz when needs to.
i am just curious what most folks use on their desktop. i've heard things like balanced still hinders gaming, while others say it doesn't.
Mon Jan 06, 2014 12:57 pm
Post Re: Poll: what power option do you have set in Win7
With win 8 and last year with win 7 i ran high performance. Don't need the PC to go to sleep if I run something in the background. With that, I'm not really concerned with energy usage. Price per watt is pretty low down here in the south.
Mon Jan 06, 2014 2:20 pm
Mine is on balanced, no issues here. As you said, only way for it to consistently down-clock when idle.
Though overclock/voltage still results in higher power consumption regardless. When I'm running pure stock, my wattage pulled from my UPS is quite a bit lower if I recall correctly.
Mon Jan 06, 2014 5:37 pm
